I got e46 m3 smg.
Changed clutch and flywheel and slave cylinder from local shop.
After replacement, I drove a day and parked.
The next day, I tried to start the engine but the smg warning light as well as engine service soon light came on. and won’t start. gear does not change at all (it should change between 1st and neutral even engine is not running) and error code 59 popped up when scanned.
The local shop says error code 59 is about smg actuator or accumulator (whatever), and since they did not replaced those, they are not charge of this symptom.
They said Salmon relay and fuse are ok (can it be even tested?)
Seriously? Can something goes wrong naturally RIGHT AFTER the service?
Is there anyone who has any idea about this?
Please, I need help. I’m so frustrated
