Hey all,
Just a quick intro here. Will post more pictures and info later on..
My e36 started life as a 318i manual. I ran coilovers and wide offset steelies. I sold the car and bought it back when I realised how much I missed it.
When I bought it back the engine was blown and it was in a pretty sorry state but I was happy it was back..
I went through many ideas about engines. I had a M50 2.0l I was going to turbo, a alloy block m52 I was going to balance and itb and finally I have stuck with an engine. It is a m62b35. I have a pmc adapter kit to mate to the 4/6cyl gearbox. I'm in the process of making mounts etc. I am progressing through making an itb manifold and running custom itbs(not s62).
Recently I acquired a pair of genuine ac schnitzer bars and am now wanting to make this into what, in my opinion, the acs vehicle should have been.
I have found some acs e34 wheels and a deck spoiler. I am working through a f22 msport brake upgrade.
I am building this as a wedding car for my partner and I for next September. A lot to do, I know!!
I really need some acs skirts and want a acs roof wing. Any ideas or guidance or donations or parts support or a friend of a 'friend who knows a guy that has the skirts' would be GREATLY APPRECIATED!!!!!!
Now to try and give you guys some pictures..
Sent from my SM-G930F using Tapatalk
Nooooice!
How did you get those brake calipers to fit? adapters?
Sent from my SAMSUNG-SM-G890A using Tapatalk
They bolt straight onto non m hubs
Here is a pic
Nice!
I'm assuming the rotors have to be upgraded to F22 as well or did you keep the stock rotors?
Rotors are the issue. That is a m4 caliper to suit a 380mm(i think) rotor. The f22 calipers will bolt straight on like this one though and I'll be able to run a 17 inch wheel.
As for the rotors, the f22 have a 20mm higher hat height. The solution is a x5 30d e53 rotor. They have a 332mm diameter(8mm smaller - only 4mm radius) which is manageable. They have a 10mm larger hat height which is manageable and a still a 30mm width. All in all it is the best option available without going to a dba 5000 series 2 piece rotor at 500 dollars a pop
what was the wheel setup with those steelies? I really like that look
In for the F22 Brake upgrade results.
Been tossing and turning on the e46 330/328 swap, so this is very interesting.
