Estoril Blue 1997 M3 Sedan 5 speed. Paint is not great, but car is solid. The hood, top of Trunk and front portions of fenders have clearcoat gone...for some reason the rest of the car is fine.
Interior - Aftermarket Reclinable Seats in Front with Double Locking Sliders/Wedge Brackets. Rest of interior has been gutted for track preparation or track/street car. Heat and AC are still functioning. No radio. Have some of the interior parts, but not door cards, rear seat, headliner and carpeting.
Chassis - Never wrecked/Bent, All VIN Stickers for all panels in place. Clean Title.
Engine/Drivetrain= Very Strong S52, especially with the Markert Tune...put a track pipe with no catalytic converter. M50 intake on it to open it up. Brand new rear main seal. Brand new Clutchmasters Stage 3 clutch with Fidanza lightweight flywheel. New rebuilt driveshaft and center support. Tranny shifts great, no noises from Diff.
229k Miles on the Chassis - Headgasket was done at 183k Miles (Markert) Compression test all cylinders from 195 to 205.
Clutch, Pressure Plate and Flywhweel has less than 200 miles on it
Full Cooling System Replaced - 4k miles
Tie Rods/Steering Rack Replaced - 8k miles
Pulleys/Tensioners/Serp Belt - 6k miles
Injectors Rebuilt
Shift Bushings Replaced
Modifications:
• Markert Motorworks Track Tune (secondary 02 Delete, Air pump delete, M50 Manifold)
• M50 Manifold Conversion (M50manifold.com kit)
• Clutchmasters FX300 segmented Kevlar Clutch, Power Plus Pressure Plate and Fidanza Lightweight Flywheel
• AKG Bushings - Subframe, Diff, RTAB's
• UUC Cat-Back
• H&R OE Sport Springs
• Swapped Strut Hats (for more camber)
• Bilstein Sport Shocks/Struts
• H&R 15mm Front Spacers
• 17 x 8.5 DSII wheels all around square setup (225/45/17 Direza II tires)
and 1 spare DS 2
• Mishimoto Radiator
• UUC Shift Knob / Aftermarket Seats
Car has had a tremendous amount of maintenance on it (Markert, others & myself).....I was in the process to build and a fully built/caged car became available...so i bought it....my loss is your gain!! If you are making into a track car/drift car/street mod it's got stuff in all the right places.
$5700 OBO
Bump
