Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 7 of 7
Thread: What wheel spacers to use on an e36 328i???
    Aug 2017
    USA
    1996 e36 328i
    Hi buds I'm new here and need some opinions on which wheel spacers size to go with on my 1996 e36 328i?? I'd upload a picture but can't. Any feedback is appreciated thanks. Ps I have 18in rims on it and will lower it as well. 225 /40 -18 tire width with 18in rims/don't know width.drop a comment please
    Aug 2013
    1999 BMW M3 Coupe
    Depends completely on your wheel width/offset and tire width. I use 12mm spacers in front and no spacers in back on my E36 M3, with 245/40-17's on 17x9 ET42 wheels. Can't really go much wider than that on an E36 without fender mods.
    Aug 2017
    USA
    1996 e36 328i
    Thank you, why don't you have spacers in the rear?
    Aug 2013
    1999 BMW M3 Coupe
    I use the spacers in front because my front tires are much wider than stock and I need more space between the tire and the coilover. The front fender lip has loads of clearance with the stock tires, so it's not really an issue unless you go wider than 255 or want to run a really low offset.
    In the rear there's no coilover to worry about, but the fender lip offers very little clearance even with stock tires. Mine are a bit wider than stock, so there's even less room. No need for a spacer there, and if I used one I'd have to cut my fenders off.
    Basically, on my car in stock form the rears were already pretty close to flush while the fronts had big fender gaps. Now with a wider square tire setup and spacers in the front it's much closer to flush with the fenders in front. That said, I didn't do any of that to my car for looks, but to run wide sticky tires for the track.
    Aug 2017
    USA
    1996 e36 328i
    Would you suggest lowering it first then putting on spacers? Thanks man
    Aug 2013
    1999 BMW M3 Coupe
    You could do it either way, though unless you want to go really wide it'd probably be easier to lower first and then get the perfect spacers for that ride height.
    If you want to be really aggressive with the spacers, get the spacers in first and then drop the ride height as much as you can without rubbing the fenders. Camber will also make a big difference if you're pushing the limits of fender clearance. More negative camber gives you more fender clearance.
    Aug 2017
    USA
    1996 e36 328i
    Thanks appreciate it
  1. Replies: 0
    Last Post: 11-30-2008, 11:42 PM
  2. what to replace on an E36 M3 to make it reliable.
    By sambam27 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2007, 05:13 PM
  3. WTB: Wheel Spacers to put on my e36 M3...
    By PourkyM3 in forum BMW Parts Wanted
    Last Post: 11-06-2004, 04:08 PM
  4. What Rims to get on an e36 318is coupe
    By Naked|e36|318is in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-18-2003, 12:19 AM
  5. So can an E39 M5 Steering wheel be used on an E36 M3?
    By mikeinsanmarcos in forum 1992 - 1999 M3 (E36)
    Last Post: 02-24-2003, 12:47 PM
