Results 1 to 25 of 29
Thread: Hard to take off in 1st gear
    May 2016
    Dallas, TX
    2008 335i
    2002 330ci 5 speed. I can hardly take off when giving it less than 1200 or 1500 rpm. Otherwise, motor bogs down, something rattles under hood, and feels like it's going to stall. Rpm drops dramatically as well.
    Symptom is much worse when the A.C. is running.
    It's also hard to control the throttle input any thoughts on what my problem might be?
    Dec 2015
    Fresno, CA, USA
    2005 BMW 330Ci Coupe
    Quote Originally Posted by hbrandon1987 View Post
    Sounds to me like a fuel issue or a clutch issue.. maybe clutch is worn? Also possibly a large vacuum leak.. I'm probably wrong though, that's just where I'd start to look for the issue
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    +2: Read the codes and look for a vacuum leak. Seems the leak is tiresomely common on injected bimmers which have accumulated some age and experience.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Aug 2017
    America
    EnriquekalOG
    Before you remove the compressor, just take the belt off to confirm thats the problem.
    Dec 2015
    Fresno, CA, USA
    Quote Originally Posted by Enriquekal View Post
    wut
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing any drivability issue is to scan the engine computer (DME in BMWeze) for codes. The SES light is on only when an emissions related code is present. I'm betting you have vacuum leaks.
    May 2016
    Dallas, TX
    2008 335i
    Quote Originally Posted by MarcoZandrini View Post
    Sorry for delayed response, been busy. My friend plugged it into INPA or whatever that program is and there are no hard codes. He did say that it had and "error" with the camshaft position sensor intake side.
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    The symptoms are similar to a car with vanos seals going out. or are already leaking. Using AC amplifies the condition. This problem will also set a camshaft fault, and a few others that dont seem to go away.
    Level 1 Certified BMW tech.
    May 2016
    Dallas, TX
    2008 335i
    Quote Originally Posted by 90turbo1 View Post
    Thanks, turbo. My recent research has been pointing me in that direction, but wanted a little bit of reassurance before taking on a 4-6 hour job.
    I'll order the seals. Will order new spark plugs as well while I'm in there.
    Over the past few days been trying to chase down another issue, I think my vanos solenoid is leaking, or exhaust cps is leaking oil. Something is leaking into my vanos exhaust solenoid connection and it's full of oil down there in the connector.
    Sent from my SM-G925T using Tapatalk
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    DIY, the seal change takes about 4-5 hours start to finish the first time. It will be unreal how much of a difference it makes in the powerband.
    Apr 2009
    Monroe MI
    2001 330ci, 1992 535i
    Wanted to share my recent experience with drivability and shifting issues I was having. Gear changes, especially 1st to 2nd would be clunky and reverse would feel like it was about to stall. I started to suspect the clutch. After replacing the serpentine belt on my fiancé's Escape, which resolved a ticking AC compressor and improved shifting (it is a stick), I thought to change mine. I used the Continental Elite Belt on both Escape and my 01 330ci. I had about 60k on my old belt and there was no visible cracks or splits but compared to the new belt, it was stretched out. To my surprise this got rid of my shifting issues and the vehicle drives like normal.
    Not saying that this will definitely fix your issue but if you have not changed your belt in 40k or so I would highly recommend it and it is cheap and easy job to do. Hope this helps
    May 2016
    Dallas, TX
    2008 335i
    Not sure how old my belt is. Will keep this in mind. Just finished the grueling job of changing the vanos seals. Car seems to have better throttle ressponse, but the main problem persists.
    Apr 2009
    Monroe MI
    Thumbs up
    Agreed, vanos seals was an annoying job.
    May 2016
    Dallas, TX
    2008 335i
    I don't want to keep throwing parts at it. I'm at the point of deciding to get a diagnosis from an Indy shop.
    May 2016
    Dallas, TX
    2008 335i
    Ended up replacing my crank case valve ventilation system, did not help. Though the car drives a little smoother now.
    I've given up on this and will just adjust my driving style.
    I'm still trying to rack down the rattle. It sounds a bit like in this video: https://youtu.be/3-h8hGmup0k
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    belt pulleys or ac compressor clutch.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    A very quick way to confirm any vacuum leakage...wave a propane torch...un-lit of course...while the engine is running. If any of the many vacumm hoses are sucking air, the propane will cause a jump UP in rpm.
    Dec 2013
    Chicagoland area
    EXOTICS
    Definitely check your DISA for rattle.If it is rattling, remove and replace ASAP, as a loose pin will cause severe damage.
    Also I would remove and clean IACV, just to rule it out. Here is a diagram-#7 DISA,#9 Idle Valve:
    http://www.realoem.com/bmw/enUS/show...diagId=11_2879
    May 2016
    Dallas, TX
    2008 335i
    Quote Originally Posted by MIKYZZ4 View Post
    I thought I had mentioned, I have already inspected DISA and already cleaned the ICV.
    May 2016
    Dallas, TX
    2008 335i
    Quote Originally Posted by Eaglesail View Post
    It doesn't seem like a vacuum leak. It sound like something mechanical. My next step is to check the pulleys and attached accessories.
    May 2016
    Dallas, TX
    2008 335i
    I just took off the accessory drive belt. The car is able to take off MUCH more smoothly now. Also no rattle!
    Drove it around the block and bakc and forth in the driveway for a few minutes.
    I guess now I have to figure which accessory is the culprit. Alternator, water pump, or PS pump. I have no history on this car. The water pump looks like a URO... That's aftermarket right?
    Nov 2010
    McNoobsville
    3 Series
    Is the car new to you? Did the previous owner install a lightweight flywheel?
    Edit: looks like that's not it.
    May 2016
    Dallas, TX
    2008 335i
    Quote Originally Posted by testify View Post
    I've only had the car since June. I don't believe it has any modifications. I'm going to replace the water pump tomorrow and pray that it fixes it. It would be amazing to have the car running properly. Being ocd it really bothers me to have this issue. If I was more financially stable I'd go lease a new 440i
    May 2016
    Dallas, TX
    2008 335i
    It was the water pump. Problem solved!
    Osnabrock, ND
    I fail to see how a water pump will make the motor rpm hunt up and down like you describe. or where you talking about the noise.
  1. Let's talk oil pressure at idle and a flickering oil light when taking off in 1st
    By ///M3Augy in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-25-2015, 04:06 PM
  2. Replies: 2
    Last Post: 02-13-2008, 02:28 AM
  3. Hard to get it in first gear? - Mine's fixed!
    By The Letter M in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2007, 10:17 PM
  4. Headlining hard to take off ?
    By skanders in forum 1991 - 1999 (E36)
    Last Post: 05-28-2007, 01:02 PM
  5. Taking off in 2nd gear?
    By Black///M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 04-19-2007, 06:33 PM
