Results 1 to 12 of 12
Thread: Rear suspension guru needed
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Perhaps I'm in denial, but I am hoping for a relatively easy fix for my rear wheel steering system. No, I don't have a euro CSi, so therein lies my problem. The left rear wheel likes to go off for a bit of a wander. The right wheel seems tight, but after 125,000 miles, who knows? I ate a set of tires in 9,000 miles--both worn evenly bald. Both bearings seem tight. I've figured out two things. First, I don't know how to evaluate bushings to tell if they are worn vs. worn out. Second, there are a crap ton of bushings on that rear end. I cringe at having to replace them all. But perhaps I am destined to. I can tell that bushing 23 is totally kaput because the center pin moves in and out. But that is not the load it was designed to carry. So which bushing failed to allow the pin on 23 to slide in and out? How do you put torque on the rear suspension to see what flexes but should not? I've reached the limit of manual pushing and pulling (I pooed a little when I rocked a jack stand). And is all this evaluating in vain--do I have to drop the carrier anyway and get a set of special bushing presses, meaning I might as well change bushings by the dozen? Thanks.
    Brett
    Sponsored
    https://www.realoem.com/bmw/enUS/sho...diagId=33_0198
    Mar 2008
    montreal,Canada
    bmw 850
    I am not a guru but i can tell you i changed all the bushings in the back at 70000 miles. I Really needed to change 4 out of the lot but its silly to just change the ones that need changing. Its a different car after that. As far as 23, its a spherical bearing and if the center tube is moving in and out it is long gone. At the mileage you have i would change them all and cross them off your list.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    You are overdue for a rear suspension rebuild. These bushings not only fail with mileage, they fail with age. I replaced all of my original bushings several years ago and the car is super tight now - a real joy to drive (which it already was previously, only now it is 100x better). You will need to get a hold of WOKKE for the upper rear wishbones, as this part only comes with the bushing. Stay away from the polyurethane crap, unless you want to do this work over again in the not to distant future.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Quote Originally Posted by ltbrett View Post
    You'll need a special tool to replace that ball joint on the car although I have seen it done with hardware from Home Depot. It's a lot easier using a hydraulic press but you'll need to remove the hub and getting the drive shaft out can be a bitch. You shouldn't need to drop the subframe. I've never seen one of these get so bad that the center pin moves in/out.
    A shop will use a pry bar to evaluate your bushings.
    Dec 2007
    Dallas, TX
    It is way easier to drop the complete carrier (4 bolts). You need to make sure to loosen ALL the nuts to every ball joint and fastener before you drop the subframe. Great opportunity to install a rear CSi swaybar (big difference in handling).
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Quote Originally Posted by TxGR8White View Post
    +8. You can tackle everything needed with it out of the car in one shot.
    What "thumbs up" really means
    Aug 2017
    UK
    E31
    What are the difference pros/cons between going with OEM rubber and the spherical bearings from wokke?
    Mar 2011
    Better handling at the expense of some ride comfort. The Wokke bits will no doubt last much longer.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Looks like I was in denial after all. I knew the right answer would be to just drop the carrier and do them all, but crap, $2000 worth of bushings? Gold-plated bushings?! I should have gone into the busing business.
    Brett
    Dec 2007
    Dallas, TX
    When I did mine, I purchased the bushings from AutohausAZ, as well as my local Foreign Car Parts store - no where near $2000.
    Also, you might want to take all of the fasteners, clean them and then have them yellow zinc plated (costs about $35 - much cheaper than replacing with new), to put the corrosion protection back on them.
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I am been searching this site, all the DIYs, and Timm's site, but I cannot find the torque values for any of the suspension components on the front or rear of the car. Does anyone have a list or can post a link? Thanks,
    Dec 2013
    San Antonio
    I just found the link to the BMW workshop manual with torque settings: https://www.bmwtechinfo.com/repair/m...ex_NV_S_TT.htm
    And, according to Dragon850, 'goodandtight' should work!
    Also found several links that Taylor provided.
  1. rear suspension help needed
    By muddylimejello in forum 1991 - 1999 (E36)
    Last Post: 05-31-2016, 09:37 PM
  2. Rear Suspension Rebuild: Need help with selecting tools
    By Tony Rome in forum 1999 - 2006 (E46)
    Last Post: 09-17-2011, 10:10 PM
  3. Rear suspension help needed
    By Racer Doc in forum 1975 - 1983 (E21)
    Last Post: 11-09-2005, 10:02 PM
  4. Rear suspension help needed
    Last Post: 11-06-2005, 10:27 PM
  5. suspension guru needed
    By Madd96///M3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-21-2003, 01:21 PM
