Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: Need help. Poor running. OBD-1 w/rk tunes. Not sure what else to look at.
  1. #51
    Virginia
    97' m52 turbo
    Do you have any E36 guys close by that can come by and help you out?
    Maybe someone on here? If I were near I'd try to help you
    It always great to have a second set of eyes
  2. #52
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    No one very close. That’s ok though. I am gonna get a second set of eyes on it.
    gonna chase wiring tomorrow.
  3. #53
    Sep 2009
    Syracuse, NY
    car is finally running after a long time with a knowledgeable mechanic
    so the main culprits were a bad ground that was allowing the charging system to not run right, the timing/vanos was not timed correctly, random wiring/grounds needed to be refreshed, wideband O2 sensor was not accurate.
    crazy this has been over a year of trouble shooting.
  4. #54
    Mar 2013
    Upstate NY
    M3
    Congrats, let me know about them wheels! Happy for you! Let it rip!!!
  5. #55
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Great news! A sorted out turbo E36M3 is a lot of fun but many of these older and modded cars need some sorting and it helps to have someone with both stock and modded experience working on it.
  6. #56
    Sep 2009
    Syracuse, NY
    I completely agree. I wish I had brought it to someone last year so I could have enjoyed the car all summer.
    from what I have been told it runs fantastic now, can’t wait to get it back.
  7. #57
    Feb 2008
    Wilmington, NC
    95 M3 Turbo, 08 M3 6MT
    Reviving an old thread - hopefully vr6dubny is still on here. After getting married, two kids, COVID, new job, house, etc, etc, I'm finally back to trying to figure out my idle issue with my OBD1 RK Tuned car.
    vr6dubny, do you still have the car, does it idle great?
    I've done much of the same that you have except replace the stock FPR with an aftermarket. Since this thread, the only change I've made is adding a ground wire to the DME, but that didn't help. I do plan to go to OBD2 eventually but need to get this thing running right so I can enjoy it once again.
    The car made 515 rwhp at CES when originally tuned, but never idled right, with one caveat, so I think you're on to something with the charging system... The only time it would idle right is when I would jumper the battery to my (old) E90 M3. I have tried two separate alternators in this car and neither made a difference, so I'm assuming it is something between the Voltage Regulator in the DME and the alternator itself.
    Do you have any insight on this?
    THANKS!!!
    1995 M3 Coupe - Cosmos - CES Built S52 Bottom End - JE Pistons - Eagle Rods - S52 Cams - GT3582R - SPA T3/4 Manifold - RK Tuned - 513rwhp
    2016 Ford F150 SCREW - Leveling Kit and Tires for now
  8. #58
    Sep 2009
    Syracuse, NY
    My issue ended up being a wire/relay grounding out causing the low volt signals to be erratic. I would check in your fuse/relay box by the driver front shock tower. Also run a volt meter to the wiring for the MAF and the coil packs.
    The fact that when you had sustained voltage from your other car it ran correctly, makes me think it is prob not a fuel issue. My guess is old garbage wiring.
  9. #59
    Feb 2008
    Wilmington, NC
    Quote Originally Posted by vr6dubny View Post
    Were you checking these voltages with ignition on, or engine on? I'm guessing engine off, key on. I would think it would blow a fuse if a power wire was grounding out? You mentioned alternator issue earlier, was there a problem there?
    I ohmed all of the sensor wires in the engine harness years ago, but maybe it's time to do it again and check all of the wires in the fuse/relay box.
  10. #60
    Sep 2009
    Syracuse, NY
    If I remember correctly it was a relay in the fuse box grounding on a ground post. There was never an alternator issue. It was not a 12v issue it was a signal wire issue.
  11. #61
    Feb 2008
    Wilmington, NC
    Hopefully someone else can confirm here - is O2 the only sensor that becomes active in closed loop?
    My car idles fine until it hits open loop. If that's the case then I'm going to dig right into the O2 wiring first and see if my issue is there.
  12. #62
    Sep 2009
    Syracuse, NY
    I had an 02 sensor that was faulty out of box and a wiring issue. I would make sure your MAF signal is staying good while running as well as O2
  13. #63
    Feb 2008
    Wilmington, NC
    So I checked the O2 Sensor wiring back to the DME and relay.
    At first start, relay is off and not sending 12V to the heater circuit. Once it's warm, I'm getting 13.5V at the O2 sensor on the heater circuit (pins 3 and 4). It looks like this is ass backward, no? Shouldn't the heater only run while warming up?
    I've got continuity between the O2 sensor plug and the DME/Relay all reading 0.5ohms or less.
    As a side note, it looks like someone went through this harness and removed unneeded stuff before I got my hands on it. They did a good job, but that doesn't mean they didn't make any errors.
  14. #64
    Feb 2008
    Wilmington, NC
    How steady should the voltage be coming off the MAF at idle? With O2 unplugged and a steady idle (12.5AFR), It's fluctuating from 0.68 to 0.74 Volts.
  1. Replies: 0
    Last Post: 10-21-2014, 05:37 AM
  2. Need help... M42 running rich.
    By kingsly in forum 1991 - 1999 (E36)
    Last Post: 01-05-2009, 04:50 AM
  3. Need help with running issue
    By red88M3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-01-2007, 02:25 PM
  4. Looking for tires- Any help not sure what direction to go.
    By Garrett M in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-11-2007, 09:20 PM
  5. Need help, im running out of time
    By BMWM3RYAN in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2006, 01:11 PM
