Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: No Start/ No Crank 1997 328is Issue
  1. #26
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    I hate to be so confused all of the time. The ignition switch is toast? THIS CAN MAKE THE CAR NOT START. Roll the car and dump the clutch, it should start.
    Quote Originally Posted by spyderg0d View Post
    Or the starter is bad and sucking ALOT of power thus resulting in a low voltage to the oxygen sensors and resulting in a misread and lean codes.. ... .
    This is a poor guess at best. The codes do not get posted during a Start Cycle, they come after the engine is already running. He's not getting Lean Codes, by the way.
  2. #27
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Ghost codes still accur during a or low voltage startup. Lean codes regardless. A faulty ignition switch to be assumed at fault from a no start based on that the car pop starts is equally a poor guess at best. I think your being a bit overly dramatic about this. Just get a meter and check the voltage drop a few times and see if it goes under 11v which is about where the dme really dumps. And also check the ignition switch terminals for 12v and continuity with the key turned. It's not a big deal like some magical diagnosis pissing contest. What is the deal.
    -Oakdizzle
  3. #28
    Aug 2017
    Na
    Na
    I don't own a meter and don't know how to use them. If I did then I would have done it. Tomorrow I will take the intake manifold off and try to check voltage, or just remove starter and have autozone test it.
    Codes are also a couple of weeks old, before the car had the starting problem, will recheck codes that are present now tommorrow as well. Thanks for all the help
  4. #29
    Aug 2017
    Na
    Na
    Tried to start the car and just realized the really low sounding click also occurs when I turn the key and the clutch isn't pushed in, but since my car is a 1997 it means that the clutch must be pushed in to start. I'm starting to think this isn't a starter problem but more or less an electrical. Anyone have any tips?
  5. #30
    Aug 2017
    Na
    Na
    Quote Originally Posted by JDStrickland View Post
    The first time I tried to roll the car and dump the clutch it worked. And I just did it now as well and it worked. Does this guarantee the starter is at fault? If so I'll replace right now and post feedback
  6. #31
    Nov 2013
    Oneida, NY
    Not really. However it is a posative test to ahow that its something involvedbwith the starter. Anything from the ignition switch to the clutch switch o the wireing to the starter. The only way to see specifics is to either start swapping parts or checking them. No one can do this except you or whover is physically there to inspect the car
    -Oakdizzle
  7. #32
    Dec 2013
    Chicagoland area
    EXOTICS
    Everyone is just guessing, as you are not able to perform tests,
    and your performing a lot of unnecessary work.
    Remove starter-have it bench tested-replace if defective-DONE!
  8. #33
    SanDiego,Dallas,Miami,Orl
    Too Many
    Crank sensor
    Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
    Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
  9. #34
    Too Many
    Also check fuse 18 iirc
  10. #35
    Apr 2015
    USA
    1998 BMW 328is
    any update op? I'm curious to know what went wrong
  11. #36
    Aug 2017
    Na
    Na
    Sorry for the late responses. I have been in the process of trying to take out the starter motor, but I cannot seem to get this e12 torx screw out. It is almost impossible. I have tried sockets and two different wrenches but it just won’t come out. I also lost two other screws in the process of taking out the intake manifold. This is just one big mess. Any tips on how to take out this starter? Thanks all!
  1. Replies: 122
    Last Post: 04-18-2017, 11:59 AM
  2. 413 no start, just cranking
    By link16 in forum 1991 - 1999 (E36)
    Last Post: 10-23-2011, 12:54 AM
  3. Replies: 9
    Last Post: 12-26-2010, 12:59 AM
  4. 96 328i No start/no crank
    By dtom4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-21-2010, 12:48 PM
  5. Need Help!! Crank No Start!! No Engine Light!!
    By ALLADULTVIDEO in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2008, 09:01 PM
