Results 1 to 4 of 4
Thread: VIN Change
    Sep 2003
    Bolton
    98' Z3M, 02' 911 C4S
    VIN Change
    Anyone know how to modify the VIN of the ECU? I have 2 cars, a salvage donor with the S52, and the base car its going into. Ideally, the ECU will match the body so I'd like to have the ECU updated to the VIN of the good body.
    Jul 2004
    Houston, TX
    36 Cylinders
    You would have to perform a flash update to the ecu with WinKFP or similar, at which time inputting the correct VIN. However, the old VIN will still be stored inside, and is much harder to remove.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2003
    Bolton
    I'm assuming that if I have the EWS disabled prior to making changes it'll avoid having issues once the VIN is updated?
    Jul 2004
    Houston, TX
    36 Cylinders
    EWS is super easy to align into an EWS2 car. Not really necessary unless this is for a swap into non-EWS car.
    A mismatched dme to ews will only stop fuel and spark, it will not give you issues updating/flashing/diagnosing etc. Everything else works, except running the engine, when EWS is mismatched..
    -Abel
  1. Change VIN in DSC or DME
    By mmolk in forum Diagnostic Software
    Last Post: 08-08-2023, 06:08 PM
  2. Change VIN in KOMBI with NCS ?
    By goofy79 in forum Diagnostic Software
    Last Post: 04-26-2017, 04:51 PM
  3. e38 cluster vin change
    By vegaslightsss in forum Diagnostic Software
    Last Post: 12-27-2014, 04:18 PM
  4. Confused! How to change VIN of NAV03 (E65) ?
    By Bluebrain in forum Diagnostic Software
    Last Post: 08-19-2012, 07:01 PM
  5. WinKFP CLUSTER VIN change possible?
    By E39bmw in forum Diagnostic Software
    Last Post: 11-05-2011, 09:35 AM
