Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: Am I getting shagged? Driveshaft, 100k svc, Fuel Filter, etc.
  1. #26
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Not a pest, 26127501257 is the entire assembly with bearing. Buy the butyl rubber strip that goes with it as well. Its $5 and prevents harmonics from the CSB traveling to the cab.
  2. #27
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Quote Originally Posted by dhurley34 View Post
    You're the best! Got it!
  3. #28
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    IMG_3980.PNG Much better than $1100.00.
  4. #29
    Fresno, CA
    2002 330i, 2000 528iT
    Much better!
    | 2002 330i 5-SPD - 101k | 2000 528iT - 146k |
    My E46 Maintenance Thread http://forum.e46fanatics.com/showthread.php?t=1124584
  5. #30
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Quick update on status of wheels. Had them checked by Quicksilver this morning (only $40 - well worth the peace of mind). No warping on any of them but none of them had been balanced correctly. Parts for DS should be here Wednesday. Slight shimmy in the front end completely resolved. Thanks everyone.
    BTW the computer setting for balancing this type of wheel is ALU-2.
    Proud owner of a haunted, 92 year old Craftsman Bungalow.
    Fastest Caulk Gun Slinger in the south (November-February).
    I'm not brilliant or beautiful ...but I'm handy.
  6. #31
    Aug 2014
    Lawrence Kansas
    ALU-2 means sticky weights only.
  7. #32
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Good to know. I've had the car in four times in 6 months trying to get the tires balanced. The last time I took it back in they told me all 4 wheels were warped. The obvious problem was that they were using the incorrect weights. There were clip weights on all four wheels. With the correct weights in place the car no longer has a shimmy on acceleration or braking. I had already ruled out brakes and CAB's, by having both inspected.
    Is it just me, or is it an industry standard to give women bad information? I'm beginning to develop a complex.
  8. #33
    Aug 2014
    Lawrence Kansas
    Sometimes these cars are sensitive to the way the wheels are mounted in relation to the balance of the brake rotors. The key indicator is if there's an intermittent shake that comes and goes around 60mph with straight wheels and tires but cant be balanced out even with road force. Taking the front wheels off and rotating them 90 degrees or 180 degrees on the rotor then remounting usually takes care of it.
  9. #34
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Interesting information. So, the incorrect wheel weights had nothing to do with it? My shimmy was worse on acceleration/braking at lower speeds and decreased significantly at cruising speeds. Is this the same thing? I have so much to learn. I'm going to need a brain transplant!
  10. #35
    Aug 2014
    Lawrence Kansas
    Not the same thing. If the balance was off, then that was your problem. Im talking about a shake when all else fails.
  11. #36
    Fresno, CA
    Worn control arm ball joints/ control arm bushings can cause the car to shimmy. In my experience, tires out of balance usually vibrate at a certain speed and go away with more or less speed. Warped brake rotors cause the steering wheel to shake when braking.
    https://youtu.be/83Pw3V8pMeI
  12. #37
    Jan 2018
    Odessa, NY USA
    1997 BMW 328is
    Can someone please tell me how I to post a question/issue on here? Sorry for being a little slow on the intake I guess you could say,,,, but I have seriously looked now for the last 30 minutes and I have decided to throw in the proverbial towel and ask for assistance....... Thanks ahead of time for the help.... Greg L
  13. #38
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I’d call fcpeuro to get the correct parts. The company’s customer support is excellent as the people know their stuff.
  14. #39
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by Gregarius33 View Post
    You have to exit the thread, and enter a specific forum/sub-forum,
    close to the top of the page you will see- +Post New Thread
  15. #40
    Bellevue, WA
    335d, 328xd (had 330xi)
    To "exit the thread", go down near the bottom and look for "Quick Navigation". If you click "Go", it will go to the forum listed. You can go to any sub-forum that way.
  1. What am I getting myself into?
    By C///M3 in forum Forced Induction
    Last Post: 06-24-2002, 02:14 PM
  2. WHy am i getting O2 sensor errors with my DA kit?????
    By J10B in forum Forced Induction
    Last Post: 05-08-2002, 08:49 AM
  3. Which fuel filter to get?
    By QuestMCoupe in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-18-2001, 04:57 AM
  4. Question on OEM Brake Job..am I getting raped!?
    By eeeks in forum 1991 - 1999 (E36)
    Last Post: 04-06-2001, 05:37 PM
  5. where can i get hi-flow injectors and fuel pump??
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 06:01 PM
