Hello everyone I once before removed my intake manifold to find if I'm missing some vaccum hoses connected them all back in and now the car won't idle as well, do I have to replace the intake gaskets Everytime I take the manifold off? I do take it off quite a bit so do I have to waste 20$ on new gaskets everytime or should I use some gasket maker on where the old gaskets were?
Don't use any kind of goop on those gaskets. I really can't imagine why you "take it off quite a bit", though. I hate taking off the manifold, so I've found ways to do the vast majority of under-manifold jobs without removing it.
Intake gaskets really don't need to be changed, if you've recently done so. unless you used goop on them, or pinched them. And if you're removing the manifold, to look for a leak, you'll likely cause more leaks than you solve. That's why everyone here tells people to go get a smoke test.
Chris Powell
BMWCCA 274412
It isn't just a matter of re-connecting all of the hoses. Some of them become brittle or just plain break pretty easily. They really aren't meant to be removed a countless number of times. I think the point that Bmwdirtracer was trying to make is that the simple act of removing the intake causes leaks due to breakage, much of which isn't visible to the naked eye. We see these sorts of issues on the forums all of the time.
Get a smoke test done.
get a smoke test done....
who the heck removes the manifold often? good grief - over 15 years and nearly, gosh, 500k between my various bmw's throughout the years and i can count on one hand the number of times i've removed an intake manifold. now, how many times have i worked blind under and around the manifold - yeah, that's a big number!
Yes you all do have a point but I don't really remove it that often it's just that I have been doing so recently because one time I had to swap some fuel lines then change the starter then vaccum hoses but I'm done with all those so I doubt I'll be taking the manifold off again I just need to get new vaccum hoses since old ones are pretty old factory ones and I believe that's why I got vaccum leak in first place because I was messing around trying to take the manifold off and just couldn't figure out how so I messed up some hoses because they were brittle
Hey man do these early to late 90s beamers really last half a million miles? I thought m52 motors could go 300k miles max If you really have been maintaining it since day one I've never heard of anyone with a 328i with 300k miles I have of the m44 motors since those are bulletproof but the 6 cylinder ones not too sure I know the M50 is real nice steel motor but m52 went into aluminum and plastic valve cover
The USA M52 in the 328i/is is made of cast iron for the block, and an aluminum head, just like the M50. They are essentially the same engine. Valve cover material doesn't really matter. They have equal very good reliability as long as basic maintenance has been performed.
The M44 is about equal in reliability when maintained. In fact, there is one little plastic Y tube for coolant in the M44 that usually destroys the whole engine when it breaks and spills all your coolant.
It's all about correct repairs and maintenance.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
just to be clear - i didn't say i had a bmw at 500k individually, that's across a couple of vehicles.
that said, i don't have any reason to believe a well maintained vehicle won't last a very long time.
i don't know about beamers - those are bikes, bimmers are cars.
strictly my opinion, but, it's all about maintenance, repair, and use.
1. maintain the car properly with OE/OEM parts (no chinese/FLAPS junk)
2. repair - proper repairs using quality parts (as mentioned above) without much, if any, "re-engineering" what BMW spent millions to develop.
3. use - a nice run at highway speeds every week will do wonders for a car. better yet, join BMW CCA, meet some folks, go to the track and really learn your car and how to drive.
You don't KNOW that you have an intake leak. You're guessing. Even if you were sure that you have an intake/CCV leak, you don't have any idea where it is. If you pull off the manifold AGAIN, to replace hoses which might be rotten, then you take a good chance of causing OTHER leaks.
Get a smoke test.....anything else is a waste of time.
Chris Powell
BMWCCA 274412
