Results 1 to 6 of 6
Thread: 2006 ZF 6HP19 AT kick after stop
    Aug 2017
    Czech Republic
    2006 E60 530iA
    Hi guys,
    I just want to share my findings with other fans, as I naturally don't believe every word from garage guy. Here's my problem.
    When I stop my car and leave D in position (eg.lights), I can feel kick sometimes after approx. 2-3 sec.. This happens when AT oil temperature is hot. There are no other kicks when using it (eg.when changing gears and so on), everything is smooth and works completly fine. I recently changed AT oil, which I do every 60.000 km, it has about 260.000+ km overall these days.
    Any idea what that could be? As this is not on the list of "often defects", I don't want to start changing piece by piece and leave idiots 2k $.
    Thanks in advance
    Skopky
    Jan 2016
    Ca
    2001 525it
    Te valve body pressure seals wear out causing the trans to hit hard on along stops then accelerating away. The seals keep all the pressure going to the clutches.
    Aug 2017
    Czech Republic
    2006 E60 530iA
    Excuse me, which seals do we exactly speak about please?
    Sep 2008
    Atlanta GA
    530I
    Sounds like you need to replace the solenoids in the valve body one is sticking
    Sent from my SM-G920V using Tapatalk
    Mar 2008
    Napa, Ca
    1987 M6
    A host of problems in the ZF 6HP19 transmission seem to trace back to clogged solenoids in the mechatronic valve body. You have options to rebuild yourself starting around $600 in parts, and some folks who will sell you a rebuilt valve body with a 1 year warranty. What these guys say looks good, but I have no personal experience with them.
    https://revmaxconverters.com/product...y-mechatronic/
    Jose
    1987 M6
    Livin the dream!
    Jan 2016
    Ca
    2001 525it
    The seals are between the valve body, there a four rubber tube seals and one rectangle seal the rectangle seal is housed on a plastic rectangle block in each side are the oring type seals. The bigger question what are the adaptation numbers for the clutches, if the numbers are over or negative 300, then replacing the seals may not have a big impact on the shifting.
  1. BMW 2006 e90 330i ZF 6HP19 Parts
    By Razor2010 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-19-2016, 06:19 PM
  2. who here ever fucks around at a truck stop
    By Stevefazek in forum Off-Topic
    Last Post: 08-22-2003, 01:57 PM
  3. Benefits to Re-sharking at Track after 100 Octane Fill?..
    By MSH in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-05-2003, 12:58 AM
  4. new vibration at idle after radiator swap?
    By ///Mracer in forum 1992 - 1999 M3 (E36)
    Last Post: 07-07-2003, 01:38 PM
  5. Clutch at Full/Dead Stop
    By edboc in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-11-2002, 12:20 PM
