Hi, please could anyone offer advice. I've just bought a 330d but the windscreen washer pump doesn't work on the car. So far, I've done the following;
1. Checked the fuses - all ok.
2. Removed the connector at the pump and checked the feed - no power.
3. Removed the pump and checked it off the car - works ok.
Any suggestions are very welcome.
thank you
Welcome to the Forum!
Since you didn't identify the car, I am going to ASSUME you mean the YM-03 330d Saloon.
1) Which fuses did you check? 49,52,59
2) If all the fuse are good, did you check for power at the stalk?
Lastly if you are getting continuity thru the stalk pin#9 Black w/green and the brown ground when you set it to wash? If so then I would be willing to say that the GM-5 is the problem. If not, the the stalk will probably be bad.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
