Results 1 to 5 of 5
Thread: 2009 528xi "Engine malfunction! Reduced Power" warning - could use help with this...
    May 2013
    Rockville, MD
    2001 BMW X5 4.4i Sport
    I drive and spend a lot of time working on a E53 X5 (M62 engine). My neighbor has a 2009 528xi (N52N) that is giving him trouble and I am trying to help. For a couple of days he has been getting intermittent "Engine malfunction! Reduced Power" warning and reduced power. It comes and goes. The CEL does come on, but has always been off when he gets it to me to scan. I have the BMW specific AutoEnginuity software so I can check every module. When I scan the codes, there are three related to the accelerator pedal, but the car still seems to respond correctly to the accelerator - the codes are 2D1B "Accelerator Pedal Module, Pedal Sensor Signal 1", 2D1C "Accelerator Pedal Module, Pedal Sensor Signal 1" and 2D1F ""Accelerator Pedal Module, Pedal Sensor Potentiometer".
    Valve cover gasket was done about 3 weeks ago and it had been fine since. Spark plugs and all the coils were all replaced about 6 months ago.
    I was a little worried about the fuel pump, but there are no codes for it and the fuel pump reports its voltage as 10.7V at idle and 8.2A current. Both values go up as you increase throttle. The reported fuel pump RPM is 6250 at idle and increases with throttle.
    Any ideas? Hate to blindly throw parts at it...
    Dec 2002
    Sarasota, FL
    It sounds like your accelerator pedal is faulty.
    Sent from my LG G6 using Tapatalk
    Seriously. Follow the codes. Why are you looking into the fuel pump when you have codes for the accelerator pedal?
    May 2013
    Rockville, MD
    Thanks. I know, why not check the obvious first? On my E53 the codes always seem to be something related but not the actual defect. But this one was pretty obvious when we dove into it. Decided to disconnect the throttle pedal to inspect it, maybe clean it some, and discovered everything in the area was wet (fresh water, not coolant). So, figured out he's got a water leak and the water seems to be messing with the pedal. Cleaned up the carpet good with a shop vac, and blew out the pedal assembly with compressed air, and the errors have cleared. Now he has to figure out where the water was coming from...
    Toronto, Canada
    2008 535i
    Sun roof drains or inner door seals.
    2004 X5 4.4, 01/2004 production, 285,000km
    1998 328i, track car, ~300,000km
    2008 535i, 205,000km
  1. New 535xi - Engine Malfunction Reduced Power
    By bishbmw in forum 2004-2010 (E60,E61)
    Last Post: 03-24-2012, 07:29 PM
  2. Engine Malfunction / Reduced Power Available
    By drgonzal in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-01-2009, 11:01 AM
  3. 2008 535xi "Engine malfunction! Reduced power" warning
    By JoDoSt in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-31-2009, 02:13 PM
  4. Engine Malfunction/Reducing Power
    By Flanker in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-24-2008, 08:49 PM
  5. 745i 2002 - Engine Malfunction - reduced power
    By hans745i in forum 1995 - 2001 (E38)
    Last Post: 12-04-2006, 07:37 PM
