Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: Effect of rear swaybar on e36
  1. #26
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by VRT View Post
    Here's a thread from the archives worth reading
    http://www.bimmerforums.com/forum/ar.../t-423480.html
    Good read.
    One quote "I calculated the wheel rate of a 19mm rear sway bar at around 32 lb/in using a motion ratio of 0.45 and an effectiveness of 70% (a guess to account for bushing compliance and other unaccounted-for deflections). That's equivalent to ~70 lb/in of spring (in the stock location)."
    That's actually a bit more than I thought it would be. Maybe I'll experiement at next track day and disconnect one end. (I'm currently running 650 springs in the rear). But...I like having the sway bar there to limit droop when I jack one rear tire up.
  2. #27
    Aug 2003
    Holland
    '97 Hellrot euro M3 SMG & '93 dakar yellow euro M3
    I run a huge split without rear swaybar.
    900 fronts with stock 22,5mm bar (95 M3)
    500 rear springs on coil over which is about equivalent to 1200 lb/in by a quick calc.
    E36 M3 S50B32 daily - E36 M3 S54 trackcar
    They Say Money Talks, All Mine Ever Says Is Goodbye
  3. #28
    Aug 2003
    Holland
    Quote Originally Posted by aeronaut View Post
    Good read.
    Data I have on E36 M3 suggests 40 lb/in (this comes from a report where one of the competitior factories got their hold on a E36 M3 back in the day it just came out, and performed a kinematics and compliance test) also it suggests 80 lb/in for the fronts.
  4. #29
    CT
    M3
    Quote Originally Posted by =BA= View Post
    BA could you post this data or article? I would be interested in reading it
  5. #30
    Nov 2010
    McNoobsville
    3 Series
    The big benefit with removing the rear bar is that the inside rear tire will droop on corner exit instead of lifting, and thus you will have more traction to put power down on exit.
  6. #31
    Jun 2008
    Lombard, IL
    1999 M3, M235i, X5D
    That makes sense. I ran most of the last year season with 800/900 springs and no rear bar. The car, while put power down OK, wanted to lift front wheel so much that it was very hard to drive. I kept putting whole car on 2 wheels! I'm running UUC rear bar on full soft and it's a lot better now, but I feel I could put power down a little earlier. I will experiment with 1000 and 1100 rear springs with no bar and see where that gets me.
  7. #32
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by r0nd3L View Post
    I also have this issue with 800/900 and a small front Ground Control sway bar. Before I go back to a rear bar, I'm going to try a larger front bar, and make absolutely sure I have no rear suspension binding/interference.
  8. #33
    Aug 2003
    Holland
    Quote Originally Posted by jakermac View Post
    That will just make it worse.
    @ VRT: I would have to look through my files if I still have the original. But I memorized the numbers.
    AFAIK original for a 95 M3.
    Springs 17 N/mm front 44 N/mm rear.
    ARB's 14 N/mm front 7 N/mm rear.
    Multiply by 5.709 for lbs/in.
  9. #34
    Jun 2008
    Lombard, IL
    1999 M3, M235i, X5D
    Wouldn't that be counter productive? I think the problem is not enough rear roll stiffness with RSB removed compared to the front. Adding more front bar, would make the problem worse.
    But, do let us know the results nonetheless.
    Btw, I have GC spherical RTABs, GC spherical lower arm, Turner spherical upper control arm bearing and new factory ball joints, suspension moves very freely!
  10. #35
    Vancouver, BC Ca
    1993 325is
    A bigger front bar would limit overall body roll which WILL help with inside rear wheel lift. I too have all sphericals in my suspension. I'm not concerned about pivot point binding, but I am about contact in various places in the rear suspension geometry. The upper spring seat centering "nub" on the chassis can make contact with the top of my GC articulated lower spring perches. I have done some careful measuring and "adjustments" so I don't think it's that. I am running 4" tall rear springs, and I know I do not have spring binding. There is 1 place that I have yet to check for contact, and that's between the upper control arm and the trailing arm. Someone recently pointed out to me that they are experiencing contact there and I have not been able to confirm or deny if I have the same contact.
  11. #36
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Jake, what is your rear ride height at the jack point with 4" springs?
    Finally got out more with my E36 this season. 560 lb/in front and 671 lb/in springs in the rear, Hotchkis front bar on soft. With no rear bar, there is a lot of mid-corner and corner exit push, it will also tripod an insane amount on corner exit. With the stock 15mm rear bar, I still get corner exit push but I don't tripod as much. The entire car still rolls a lot with these rates, more than what I think an STX car should.
    I want to bump up front rate to 650lbs and then play around with 800-900lb rear springs, all without a rear bar. Should make the car more composed when I'm hucking it around the slaloms, instead of waiting for it to settle before getting back on it.
  12. #37
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    My experience is limited, but here it is. I ran stock M3 suspension with and without the rear swaybar, but it was the 325/328 swaybar, not the M3 bar I really couldn't tell the difference at Summit Main. It rolled far more than I liked either way. Since then I have chucked the M3 stuff and I'm off on a different tangent.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
  13. #38
    Mar 2011
    Silver Spring, MD
    98 M3/4/5
    E36 M3 on 200TW Direzzas.
    I'm running a GC bar in the front (I think it's the biggest one), Bimmerworld race LCAs, 750lb front and 800 lb rear, no rear bar. I played with 600, 700 and now 800 rear springs with the double-adjustable konis on full stiff, and I think I will try 900lb rear springs next.
    It's my second season racing. You could have given me a perfectly setup car a year ago and I would have told you it was too stiff in the rear because I was turning in and not getting on the throttle, inducing oversteer. Now that I've learned to transfer the weight to the rear as soon as I turn in I like the feel of a stiffer rear end.
  1. e46 rear swaybar on E36 Will it fit ??
    By fahdyehia628 in forum 1991 - 1999 (E36)
    Last Post: 06-26-2012, 03:32 PM
  2. Need pics of mounting aluminum uprights for rear wing on E36 M3
    By JHSoCalM3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-22-2011, 03:01 PM
  3. E36 Want front a rear swaybars for e36 m3
    By cmzwirner in forum BMW Parts Wanted
    Last Post: 06-12-2010, 04:21 PM
  4. Odd Request: Pics of Installed Swaybars on Non-M e36
    By SergeK in forum 1991 - 1999 (E36)
    Last Post: 03-10-2008, 08:07 PM
  5. Question about mounting of rear speakers on e36 M3
    By Hellrot Sachin in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-24-2008, 04:17 PM
