So I've played around a bit with stock, or larger than stock. But I hear many guys completely remove the rear swaybar in e36s.
My question is, why? What effect does it have on your chassis, in your own experiences?
Thanks!
I personally run without one and prefer how my car handles without it. Not having one can make the front end push a little, but you can also dial that out with compression/rebound settings.
When you say the car pushes a little without the rear bar, would you say it pushes on corner entry, mid corner or corner exit?
Maybe this was the incorrect subforum to post this in, Mods can you tow this to the Handling forum?
My car has a little push mid corner but handles better everywhere else.
When you say "push" do you mean understeer? I'm trying to get rid of understeer in mine, especially in the wet, and was thinking of trying to play around with the sways, but if you say removing the rear bar creates more understeer I'll look for other means
Sent from my Nexus 5X using Tapatalk
Yes, push is understeer. In my car it did but it's not an apples to apples comparison given our suspensions are probably very different. The easiest way to test it is to just disconnect one of your rear end links and feel the difference it makes. Disconnecting one end link is equivalent to taking it off and is allot easier to re-connect if you don't like the feel.
Ran without the rear swaybar... holy worlds of better. The rear would rotate on power but not slide out.
I recently removed my rear swaybar. Car is very stable on corner exit, but still allows you to get the rear end out a little. Not a huge difference tbh.
1993 E36 325is
2003 E46 325iT
SpeedHunters feature: http://www.speedhunters.com/2018/04/...t-dtm-tribute/
APEX feature: https://www.apexraceparts.com/blog/m...-arc-8-wheels/
To keep this discussion going:
What size front bar are you guys using after removing the rear bar (and what spring rates)?
Dave
'18 RAM 2500 Laramie Cummins
'15 Pure White VW Touareg TDI
///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
///'72 Chamonix 2002 (Restoration project)
Prior to disconnecting the rear bar:
Stock front bar, I believe 570# fronts.
Turner rear bar, 650# rears.
680lb front spring 890lb rear.
No rear sway bar
Front UUC on full stiff connected to A-arm
Feels pretty neutral for track
1995 325is 5 speed S50B30
I like the colour, No Bias
Because Racecar
-Did you hear that?
Great info.
I'm on 550F/650R with AST 4100's. Car is stripped and caged at 2880# with me in it.
Just removed the rear bar and have both the GC large and medium front bar, but not sure which to start with? Opinions or experiences?
Dave
Some of it is personal preference and driving style. I would suggest, on those spring rates, try the big bar.
Racing Dynamics 27mm front sway bar, GC coilovers 650# front 800# rear
1993 E36 325is
2003 E46 325iT
Well, interesting fact about the GC front bars: they all use the same hardware (same OD) so you can just swap out bars. The wall thickness is what changes. The bar is $150 without hardware so I picked up the extra medium bar. Won't be back on track until October though.
Sent from my SM-G920V using Tapatalk
Dave
I'm running 10k (560lb) F and 14k (784lb) R, 27mm front bar no rear bar and am still working on dialing in my setup. The consensus for those running a rear bar seems to be that a 100lb split front to rear is ideal however I wonder what the ideal split for no rear bar is? I would think more than 100.
I just did a few events with 10k front and 12k rear, Hotchkis front bar on soft and no rear bar. Rear end definitely feels too soft without a bar.
I did a bunch of set up changes too, but I'll be putting in a bar again and doing a few more events. I think I may experiment with going with 650lb front and 800/900lb rear with no rear bar next season.
I run 650/800 with the GC medium front bar about 2" from the end, and the GC small rear bar (smaller than stock) on the softest setting. The more front grip I get, the looser the rear is, which makes sense if you think about it. For awhile I ran the rear bar at 1/2 stiff; I figured out something in the front and now my car is loose even on the softest rear bar setting. Going down 50lbs in spring in the rear (and fixing my rake!)
Test test test. Forget what you like, look at the stopwatch.
When you can get on the gas just past mid corner, stay on the gas without the front or back washing out, you're getting there. A lot of it is driver preference.
2002 BMW M Roaster.
1998 BMW 328is SCCA E Production road racer.
Here's a thread from the archives worth reading
http://www.bimmerforums.com/forum/ar.../t-423480.html
