eBMWParts
Results 1 to 13 of 13
Thread: Back to stock RTABs
    Wisconsin
    98 328IS 03 325xi
    RESOLVED Back to stock RTABs
    RESOLVED
    After putting poly RTABs in my e36 coupe, I'm considering going back to stock rubber bushings. The reason being that it is so loud in the car I hate driving with the windows up. I've checked everything I can think of that might be the source of the noise. The wheel bearings are fine as is the CSB and no noises from the dif or transmission. I've backed off the parking brakes and even driven it with the rear calipers off the rotors. What I need to know is where to position the new bushing in the trailing arm. I know if you replace stock with stock you measure the gap between the bushing flange and the arm with feeler gauges but the polys that are in there have no gap. Just center it or what? Any help will be appreciated, TIA.
    It turned out that the noise was a rear wheel bearing, the one that had been replaced once already. If nothing else a few other items got replaced in the process of finding the cause. New center support bearing and both camber bolt assemblies and bushings. Acquired a few more tools and learned how to do more repairs so it was definitely a learning experience.
    Gave away my BMWs, driving a VW and an Audi now.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    My powerflex purple rtabs were no louder than stock. If you go stock, you can use limiters. Also there is one stick rtab that is stiffer than others. Might be a Z4M application. There is info on it at the Vorshlag website.
    Oct 2003
    Seattle
    99 M3
    The new factory RTABs no longer have flanges…
    Wisconsin
    98 328IS 03 325xi
    I've got the red ones from UUC and it's the only thing I can think of. It went from speeds above 35 to most any speed now. The other day when I went from 65 to 55 mph the sound got louder. The strange thing is I can't hear anything outside of the car. That's why I figured it was NVH. These are the bushings I have. Bluptgm3, does that mean I should center them?
    Oct 2003
    Seattle
    99 M3
    Back to stock RTABs
    If those fit centered on you RTA, the clamp-up bushing was flush on both ends, and you were able to align the Toe correctly, then yes use those flange thicknesses as a guide.
    Wisconsin
    98 328IS 03 325xi
    I'm looking at the kit from FCP with Lemforder bushings and limiters and I'm waiting for a response from them because the kit is listed as not fitting my 328 coupe. But it fits every other non M e36, the same with the zm kit.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by jmo69 View Post
    If it fits M3/323/318/325 then if fits 328
    Jun 2005
    New England
    Beware some sell poly limiters that may squeak. Delrin may be better.
    Oct 2003
    Seattle
    99 M3
    Also there is one stock rtab that is stiffer than others. Might be a Z4M application. There is info on it at the Vorshlag website.
    Thanks for that tip, interesting.
    https://vorshlag-store.com/collectio...-bushings-pair
    Jun 2005
    New England
    The split bushings are more of a pain to install, since you have to compress the split as you press them in.
    Oct 2003
    Seattle
    99 M3
    Right, can I still purchase a Lemforder 'flanged' bushing?
    Nov 2013
    Utah
    97 328i
    Mine were very noisy and horrible to deal with until I greased them up with copper anti seize. OP, did you grease them properly?
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by acgrossen View Post
    Yes, they were greased with copper anti-seize and a grease designed for extreme pressure and wet conditions, aka ring grease for redi-mix trucks.
  1. Thinking of changing back to stock chip?
    By Alpine003 in forum 1991 - 1999 (E36)
    Last Post: 05-19-2004, 03:11 PM
  2. turning ECU back to stock
    By SilverBeam in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-01-2003, 01:18 AM
  3. Do I need to reset Conforti Shark back to stock
    By tripleM in forum 1992 - 1999 M3 (E36)
    Last Post: 09-25-2002, 09:08 PM
  4. Going back to Stock, LOTS for sale!!!
    By CruizinKO in forum BMW Parts For Sale
    Last Post: 11-11-2001, 01:25 AM
  5. Changing my suspension back to stock
    By yev in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2001, 10:40 AM
