Results 1 to 7 of 7
Thread: X3 Vibrations
    Apr 2008
    North Jersey, NJ
    E30, E36, E83
    X3 Vibrations
    I have an e83 x3 2.5 with a serious vibration as low as 20mph...once it starts picking up speed the vibration starts and its pretty strong.
    Shop said it was a bad diff and I replaced that but vibrations still present. I have been through various vibration threads trying to diagnose the issue to no avail. I also mounted camera under the car and dont see much movement.
    However today I mounted it in the engine compartment and noticed the engine moving a little more than expected. Has anyone experienced engine mounts causing vibration only when driving?
    Will post a link to the video once uploaded.
    Thanks for your input guys!
    I'm in the market for a decent e46 / e90 MT
    Apr 2008
    North Jersey, NJ
    E30, E36, E83
    Video: https://youtu.be/wqPVunsm_OY
    You can see the most movement around 25s, but generally vibrations are stronger when i let off the throttle.
    warwick RI
    E30/E32/F25
    Hood open with the car in drive parking brake on blip throttle a few times . The engine should have very little movement but some. Do the same in reverse. This is the easy way to check a mount. A bad mount can 100% be your problem, it can even cause I vibration in gear when your not moving
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Apr 2008
    North Jersey, NJ
    E30, E36, E83
    Thanks @e30luv318i I did try that and didn't see much movement...there is sometimes a jerk when moving to R from D but not from P.
    Will try to mount the camera underneath the car tomorrow and see if I can spot any movements at the mounts.
    Jan 2016
    Ca
    2001 525it
    Just take it to the shop and pay for some diagnostics
    Apr 2008
    North Jersey, NJ
    E30, E36, E83
    Sadly I have already been to about 4 shops (2 bmw indies) and paid diagnostics 🙈 they have all failed and simply wanted to start throwing parts till it goes away...the most credible said diff and changed that @ $400 for used diff + 4hrs Labor to no avail.
    Took it to another Indy today and eill be replacing CSB & Guibo...driveshaft is showing some scuff marks so hopefully that might be it.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    It could be your drive shaft. I had one go out and caused a pretty bad vibe. The whole shaft had to be replaced as the u joints aren't serviceable. About $800 if I remember properly.
  1. 04 x3 vibration on acceleration
    By Felisrufus in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 05-29-2015, 04:03 PM
  2. 2008 X3 vibration
    By BillWill in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 10-09-2013, 03:13 PM
  3. Vibration and spiking rpm's when 2011 x3 starts up
    By joex3 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 11-26-2011, 08:02 AM
  4. Another X3 Vibration Saga
    By srhorn in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-25-2011, 01:03 AM
  5. X3 vibration issue from rear
    By spederman in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 09-10-2011, 10:08 AM
