Results 1 to 17 of 17
Thread: What is this part? (pics inside)
    Calgary, Alberta, Canada
    1997 BMW 328is
    Anyone know what this mesh filter is from? I was removing my radiator and after draining all of the coolant from the radiator and expansion tank (along with upper and lower radiator hoses) I found this in my catch pan. I have no idea where this is from.. it might not even be from the cooling system and could have just fallen into the catch pan as i was removing the radiator..
    Jun 2010
    NY
    1997 328i
    Maybe its some kind of coarse filter from a fill can they used at the factory!?
    1997 BMW 328is
    Hopefully it wasn't floating around in my cooling system..
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    It's not a part of the car that I recognize. It's of no consequence that it fell out. If it came from something you need, you would have needed it by now.
    Australia
    1996 E36 M3 Euro 3.2L
    Could be a VANOS filter.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    M50/M52 do not have it, as the oil is directly coming from the oil filter.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Looks like a fill cartridge from a spill-free funnel. Lisle and several other manufacturers make these with caps for common radiator tanks. You screw the funnel on with various adapters based on the car/tank model and you can quickly fill and bleed the system with the engine running. That filter piece slots into the spill free radiator cap and the funnel pushes down into it. If it is one, it probably dropped into the overflow tank or maybe one of the large hoses when attempting to fill the block with coolant.
    Nov 2011
    Bonney Lake, WA
    1998 328I Sedan
    have you done any maintenance or repairs to the windshield washers lately? Looks like a washer fluid filter to me.
    Mike
    1999 750 IL (SOLD)
    1990 750 IL (SOLD)
    1989 325IC (SOLD)
    1995 540I (SOLD)
    1999 323 (SOLD)
    1998 328I 195,000 miles and counting
    2017 Ford Expedition Platinum
    2016 Lexus RX350 F-Sport
    1997 BMW 328is
    Quote Originally Posted by mikeysentra View Post
    Oooo actually I did remove my washer fluid reservoir and had to drain it to replace the washer pump. I drained the rest of the fluid into the same drain pan as the coolant. So this goes in the washer reservoir? On the intake to the pump?
    South Carolina
    2004 330 vert 2004 X5
    The only filter in the washer fluid res is where you fill it. It's about 2-3" in diameter. If the washer jets have filters they are definitely very tiny like maybe 1/4" in diameter.
    The simple answer is it's not part of the car. It got into the pan somewhere else.
    Sep 2012
    Moscow, Russia
    1992 318iS, 1997 328iS
    Yes, I also saw this filter somewhere under the hood, but I don't remember where exactly
    1997 BMW 328is
    Just thought I'd update this thread with some more pictures!
    In case anyone was curious what that filter was for..
    Rubber grommet from washer reservoir (where the washer pump goes):
    Perfect Fit!!
    Don't want to get any pesky dirt in my washer pump or nozzles!
    Mikeysentra was correct.
    Sep 2012
    Moscow, Russia
    Quote Originally Posted by Kapoosta View Post
    Perfect Fit!!
    Bingo!:-D
    The Netherlands
    DE-spec E36 328i/M3 cab
    I don't recall having ever seen a filter there.
    There is a strainer on the fill opening.
    That is an aftermarket grommet. This is the BMW part for that grommet/gasket:
    If yours was OEM, I would've known about it.
    IG:
    1997 BMW 328is
    Quote Originally Posted by MParallel View Post
    My reservoir does not have a filter on the fill opening.
    Looks like the grommet might be off an E46 or Mini... or was replaced with whatever the local parts store had available.
    The Netherlands
    On most cars the strainer is long gone, or floating inside.
    The E46 version. One piece. Separate strainer is just asking for problems.
    IG:
    Aug 2009
    sunnyvale CA
    325is
    Someone posted this filter on his E46 car.
  1. What is this leak?? Pics inside
    By astor in forum 1991 - 1999 (E36)
    Last Post: 11-01-2011, 02:20 PM
  2. what is this part (pic)?
    By Ridgeway in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-31-2006, 12:09 AM
  3. What is this part????? help meee (pics)
    By kt1 in forum 1991 - 1999 (E36)
    Last Post: 05-24-2005, 05:31 PM
  4. What is this part? (Pic attatched)
    By ExCape in forum 1991 - 1999 (E36)
    Last Post: 03-08-2005, 10:54 PM
  5. pic- what is this part?... it's leaking oil BAD!
    By Jasonb1971 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-25-2004, 10:27 PM
