Bmw E12 530i M30 Engine block, cylinder head, accessories
I have a good M30 block with rotating assembly, cylinder head,flywheel clutch plate still attached, and some accessories to the engine like distributer alternator etc. this all was from a 1975 530i E12 with 88k miles on it. Has been sitting for a while now engine block was greased no rust in bores. Cylinder head was good has exhaust manifold attached. The engine did start and run before it was pulled no smoke so the head was good and still should be good.
List Date: 7/31/2017
For more info, click here to view the original listing: Bmw E12 530i M30 Engine block, cylinder head, accessories
This item is no longer available.
Hello Jeff
Do you still have the motor & trans available ?
Thanks !
Gone!
