Results 1 to 6 of 6
Thread: Fixed vacuum leak - now *lots* of white smoke
    May 2017
    Cincinnati
    2001 325Ci
    My wife's 2001 325CI was running rough.
    DTCs said, "bad purge valve" so I replaced that. I also found a vacuum leak between the oil separator portion of the CCV and the dipstick and replaced that hose. It started, idled, and ran "like new," she said.
    Then after a short trip and a five minute errand, she called and said it was blowing white smoke. Since she was only a couple minutes away, I said "Bring it home."
    It was smoking a little when she got home: wispy white with virtually no odor. We shut it off and let it sit overnight.
    Next morning, I checked coolant: still had pressure in the radiator and seemed full. Then I started it: yup, white smoke. It didn't smell like oil or gas. I let it idle for one hour and it cleared-up. I feathered the throttle, it rev-ed up, dropped back to idle -- and started smoking like crazy. Huge, billowing clouds. I've *never* seen this much smoke coming out of an exhaust pipe! It was white and smelled a little bit burnt.
    After one minute, it didn't look like it was going to stop so I shut it down.
    What's next?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    White smoke is an indication of coolant getting into one or more cylinders. My suspicion is that the head gasket is bad. This is supported by the statement that the upper radiator hose is firm even when the engine is cold.
    has the engine ever been overheated? When was the entire CCV system last replaced?
    South Carolina
    2004 330 vert 2004 X5
    If it really is white smoke then you've got a head gasket or cylinder head issue. The fact you did a repair on the CCV system 24 hours prior kind of rules that out.
    I suspect that your white smoke is actually blue smoke from engine oil. They can appear very similar if you've never experienced both. A failed CCV system can cause oil to be pulled out of the crank case into the intake manifold. In severe cases it will create clouds of smoke so thick you can't see your hand in front of your face. It will have a slight burnt oil smell. While smoke from coolant has a very distinct sweet smell.
    When issues like this pop up it's always wise to look at any work that was performed just before the issue started. Start with the CCV system. You could have a failed cyclone separator.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    It always amuses me how quick people are to jump to the worst conclusion. Coolant has a very sweet smell when it is being burnt. Also the next obvious step would be to see if the car is actually losing coolant.
    How is this car mostly used? does it get many trips more then 20 minutes in length? Highway driving?
    Dec 2013
    Chicagoland area
    EXOTICS
    Replace CCV System as a kit, not hose by hose.
    Here is what you need:https://www.fcpeuro.com/products/bmw...-m54b25coldkit
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I'll take "What is a CCV system failure" for $200 Alex.
  1. Lots of White Smoke!!!! and smells like burned oil...
    By simplismen in forum 1999 - 2006 (E46)
    Last Post: 04-21-2011, 02:24 PM
  2. 2000 528i Sport - Hard Start, LOTS of white smoke, No turns, high beams, dash lights!
    By adrock2003 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-04-2011, 05:25 PM
  3. Lots of white smoke from exhaust, but no coolant in the oil.
    By n3rd in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-09-2010, 07:02 PM
  4. lots of white smoke after spark plugs
    By hipe87 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2009, 10:47 PM
  5. Lots of white smoke when cold start (w/ 80K Miles)
    By ctrlaltdl in forum 1988 - 1996 (E34)
    Last Post: 05-05-2005, 03:33 AM
