FS e31 passenger side fuel pump housing/assembly/carrier, which includes the housing, 2 pumps and fuel level sender. the sender works fine and up until 3 days ago both pumps in the assembly were working when applied 12v directly to the pins but now thanks to bad advice neither pump work, may be able to be brought back to life with carb cleaner and light tapping while connected to a strong battery. im trying to decide between rebuilding it with new pumps OR buying a brand new oem assembly but with tax and shipping they are $700 so if someone wants this i need to know asap before i order the parts to rebuild. pm me a reasonable offer (and keep in mind what the cost of a NEW housing is when doing so).
someone could also make some money buying this and rebuilding it to working condition, then sell it... when compared to a new $700 pump there would be many takers. thanks
" the sender works fine and up until 3 days ago both pumps in the assembly were working when applied 12v directly to the pins but now thanks to bad advice neither pump work"
You're kidding me right?
Hi. Is this still available? Thank you
possibly... i just sent you a private message, check your inbox.
