A Harness Bar for the BMW 2-Series Coupe is the perfect addition to any track, autocross, or even show vehicle. The BMW F22 such as the M2, M235I, M240I, and 228I are extremely popular vehicles for the track. The harness bar’s purpose is to allow the use of racing harnesses during competitive events to further secure the driver and/or passenger in their seats. Harnesses must be installed in such a fashion where the belts are at an angle required by sanctioning bodies such as NASA or SCCA to keep the driver safe and secure. The angle which is recommended for properly installing harnesses is parallel to the seated persons shoulders and not furtherer down than -20 degrees. With the installation of the Agency Power harness bar, drivers will be able to properly run a set of harnesses in their vehicle. In addition to providing support to keep you focused on steering wheel control, the mounting and positioning of the harness bar provides further structural integrity to the vehicle chassis.
The Agency Power BMW 2-Series harness bar was designed for an easy installation, provide an OEM fit that does not require cutting, and extreme durability. Constructed of 1018 steel with .120 wall thickness, the sections of tube are then precision welded and feature mandrel bends. Each harness bar features harness locators behind the driver and passenger seats to prevent the harnesses from sliding on the top tube. Integrated slip fit design like some of our other harness bar kits allows for it to be easily installed or removed. The rear bars feature a unique CNC machined hook design which secures the harness bar to the factory child safety latches. Finally, the symbolic Agency Power logo is centered in the top bar. Each harness bar can be finished in an assortment of powder coated finishes.
Features:
1018 Steel with .120 Wall Tubing
Integrated harness locators
Multi-piece design for easy installation
Integrated Agency Power Badge
Includes longer bolts needed for installation
Retains stock rear seats
Allows for the seat to slide all the way back
Brilliant powder coated finish
Fitment:
BMW F22 2-Series Models: M2, M240i, M235i, 228i
Notes:
NEVER let a person ride in the rear seats with this harness bar installed.
View Installation Instructions Here
All Agency Power products come with a LIMITED LIFETIME warranty
