Results 1 to 5 of 5
Thread: Need help - Suddenly running rough and "Service Engine Soon" light came on.
    Jun 2006
    NorCal
    2000 323ci Convertible
    Was out running errands around town today, when I made a right turn at a stop light, and suddenly it felt as if I was in 4th gear when I was in 2nd. I was down on power and I then noticed the "Service Engine Soon" light had come on and the car was running rough; almost like a missfire or a dead cylinder.
    The car is a 2000 323ci with 112k on the ODO and manual transmission.
    Im thinking possibly a bad injector or coil that suddenly failed. Is there a way to check fir fault codes without a scan tool like on the older models? I.e, pumping the gas pedal 5 times, etc..
    Any other thoughts on the possible cause?
    Your help is greatly appreciated.
    Thanks!
    -V
    "Sometimes, it's all about the journey..." Current Bimmer: 2000 323ci Convertible
    Past Bimmers: 2006 Z4 3.0si, 1997 528i, 1995 M3, 1989 325ic, 1973 2002 tii, 1987 528e, 1982 528e
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Since your car is OBD2, a tool is required. You can likely take it to an Autozone or a similar place and get the codes read to give you a place to start troubleshooting.
    888.280.7799 | 6am - 5pm PST
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Or... you could get under the hood and look for the obvious things like a hose that's busted, which is what I think you'll find one way or another. The E46 does not do the "stomp test" like earlier models.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Jun 2006
    NorCal
    Took the car to Oreily's and got the codes read; it appears the #2 coil has failed and I also got misfire codes from cylinders 1 and 4. Are the addition of #1 and #4 misfire codes signs of a potentially bigger problem or likely a none issue?
    As for #2, I've heard worn plug connectors are a common cause of coil failure codes on these older, higher mileage BMWs. Is there an easy way to tell if it's the connector and not the coil pack itself? i.e. Testing with a multi-meter or obvious visual cracks, etc...
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Swap the #2 coil with another coil to see if the problem follows the coil. Yes, the "boots" that connect the coil to the spark plug can and do go bad with time and repeated heating/cooling cycles. You probably should replace all 6 boots.
  1. Bmw e36 335i suddenly running rough and missing
    By CameronC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2011, 10:02 AM
  2. Need help 330XI running rough.
    By lumpy53 in forum 1999 - 2006 (E46)
    Last Post: 09-02-2011, 11:57 AM
  3. Rough idle and flashing service engine soon light
    By devoulley in forum 1996 - 2003 (E39)
    Last Post: 02-08-2011, 09:34 PM
  4. Need Help. Car idling rough and other issues.
    By bimmeracer3 in forum 1996 - 2003 (E39)
    Last Post: 07-10-2010, 01:57 PM
  5. SERVICE ENGINE SOON SES light is on.. what's cuasing it?
    By BMW Newbie in forum 1999 - 2006 (E46)
    Last Post: 03-06-2007, 12:39 PM
