Results 1 to 6 of 6
Thread: 1987 325i Convertable power windows work intermittently
    Jul 2015
    South Carolina
    Z3 & 540
    Hi,
    Sometimes my power windows work sometimes they don't. It is a weird issue to me because it can be one or two windows that are unresponsive or all of the windows that do not work. Given that they work on and off again I do not think it is a fuse or even a breaker. Are the window motors going bad? I had an older Camry that did this once and it turned out to be the window motor, but I doubt they would all do it all at once. Like everyone else in this world I do not want to overhaul the window regulators if it is a switch or something easy.
    Suggestions about how to trouble shoot this are appreciated. Keep in mind that I am not a mechanic so my diagnostic tools are very limited.
    Thanks in advance!
    Jan 2017
    Redmond
    1989 325ic
    First thing to check is the main switch on the console (front-most of 3 in line on passenger side).
    Next you can check the switches in differing positions. If you have one know-good, works-all-the-time switch, you can try it on each of the 4 window switch positions.
    Clean the contact points on every switch as best you can. A bit of emery board or fine sandpaper can help a lot for this.
    Your auto parts store likely sells dielectric grease. This can help with re-assembly and will delay the time to next troubleshooting session
    Jul 2017
    wenatchee. wa
    1989 bmw 325I
    Mine did the same thing. I changed the switches bought new ones off e-bay works fine
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    Mixing switches around to see if the problem follows the switch is a good starting point. I had a problem with the contacts in the plug in the door pillar which is prone to corrosion. Didn't find any but taking it apart and cleaning it up seems to have helped
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    Jul 2017
    wenatchee. wa
    1989 bmw 325I
    Look on e-bay Mine was doing the same thing ended up being the switches. The ones I got there work as good as the original ones
    Jul 2015
    South Carolina
    Z3 & 540
    Thanks for all the suggestions! My car is a hobby car. It sits alot (problem in itself), but I travel alot so I am just getting back to it and this thread. I'll take apart the switches and connections and clean them up and see what that does.apart
    Your photo is exactly what I have. A red 1987 325 Convertable.
  1. 1995 325i convertible power window issue
    By bobkconvert in forum 1991 - 1999 (E36)
    Last Post: 05-14-2017, 03:31 PM
  2. power windows working intermittently
    By capebmw in forum 1996 - 2003 (E39)
    Last Post: 06-22-2016, 10:54 AM
  3. [E36] 325i 94' convertible power window problem
    By E36325cabrio in forum 1991 - 1999 (E36)
    Last Post: 01-11-2015, 07:18 PM
  4. Replies: 2
    Last Post: 06-29-2011, 06:46 PM
  5. why dont my power windows work on 87 325i?
    By bmw525i91 in forum 1983 - 1991 (E30)
    Last Post: 07-08-2008, 06:35 PM
