Results 1 to 5 of 5
Thread: Godspeed Mono SS Coilovers on 1993 325is
    Oct 2013
    Southern Maryland
    E36x2, E34x2
    While I understand I will likely be subjected to a vicious verbal beating for installing this "cheap chinese crap" on my BMW (and then having the gall to post about it), here we go.
    So, my new to me $1900 325is needed some suspension work. It had three blown shocks and the ride height was too high for my liking. A few years ago I lowered my 323is some Tein S. Tech lowering springs and orange Koni STR.T struts and shocks. And last year I installed some BC Racing coilovers on my beloved 1995 540/6 Touring.
    I have been happy with both setups with a few caveats. The Koni/Tein set up was less expensive but after replacing all the misc parts it still wasn't that great of a value (forget exactly how much I ended up spending...). The 323 is low, borderline too low, but right about where I wanted it. The ride is decent, the car handles well, but there is no adjustability (except for the "camber washers" I installed behind the front struts).
    The BC Racing coilovers are IMO a great value but were still $1200 (~$1000 for an E36). I appreciate the camber plates and being able to dial in the ride height. The wheels and tires on the Touring are: front 235/35 tires on 19X8.5 (15ET)Rear: 275/30 tires on 19X10 (15ET), so it was very helpful to be able to tweak the ride height.
    After doing way too little research I decided to take a chance on a set of Godspeed Project Mono SS coilovers. They cost $630 delivered to my house...
    My cat was suspicious, here she is giving them the sniff test...
    It looks like they passed her sniff test, although she did activate her laser eyes before napping on the box.
    Packaging was excellent; there was a thick (non-Harbor Freight style) box inside the outer box, lined with more thick card board and foam inserts at the bottom.
    I was not in love with the color combination, but it looks less pink and more salmon in person. Visually at least, the quality, fit and finish of the components looks good, but who knows what lurks inside those cartridges...
    I disassembled everything to inspect and put some anti-seize on the threads before reassembly.
    Installation is pretty straight forward. An added benefit of the front units is that there tabs for using M3 swaybar links.
    I apologize for not having any post install pics to show the ride height; I will try to snap a few today. I also installed some nicer Style 30 wheels I had sitting in the basement, along with some fresh (and yummy) Potenza RE-11 tires, but my alignment guy has been out of town so I am trying not to drive it too much until I get it aligned. I did however, take the car out for a few test drives. The shocks have 16 damper settings; I started out on 8 but ended up dialing them down to 5. So far so good; the car handles and rides way better than it should. We shall see how long until one of those shocks blows up; hopefully it's before the 1 year warranty is up...
    Another note, during installation I chose to leave the rear rubber spring pads in place. This of course limits how low the rear springs will go. I ended up at max lowering in the rear without it being super low... I will post some pics tonight and I will try to update this post in terms of the long term.
    Rick
    1993 325is - The New Daily?
    1998 323is - The Daily Beater
    1995 530i - The Alternate Beater
    1995 540i/6 Touring - Lord Borthwick
    1995 540i - The Donor & Parts Locker - Finally sent to the Crusher - RIP
    Jun 2010
    NY
    1997 328i
    did you coat all the threads? Something like a molly based aerosol would be best.
    https://www.amazon.com/CRC-03084-Net.../dp/B0013J62P4
    Feb 2017
    USA
    1997 328i
    Looks interesting... I'm new to coil overs, but everyone says "BC! BC!". I've never had them before my current car (Purchased in Feb this year, and the previous owner installed some Ebay ones which are ready to be swapped out.) I've heard good things about the SoloWerks S1 coil overs for about the same price. Those are what I'm leaning toward, but would also be interested in seeing how these work out for you moving forward.
    BTW, Anyone have experience with Solo Werks S1's?
    Oct 2013
    Southern Maryland
    E36x2, E34x2
    Quote Originally Posted by Eric93se View Post
    Thank you; that's good advice. I will pick up something to help proetect those threads.
    Quote Originally Posted by Dethstryke View Post
    Like I mentioned I've got BC Racing on my E34, and in the realm of "value price" coilovers they are pretty respectable. As for the Solo Werks S1, no personal experience, but they didn't have the features I wanted like camber plates and adjustable damping. And it looks like the front ride height is adjusted by moving the spring perches which is not optimum.
    Anyway, here are a few pics of the car at (maybe) final ride height with the new wheels/tires:
    Rick
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Hi, any update?
    Sent from my Pixel 3 XL using Tapatalk
    2003 530i M Sport [Black Sapphire Metallic & Sand Interior]
    IMG_1075 by Alex Wilson Photography, on Flickr
  1. WindowS won't go down or up on 1993 325i sedan
    By R26Roman in forum 1991 - 1999 (E36)
    Last Post: 01-26-2014, 10:57 PM
  2. Fixed error code 1221 on 1993 325is
    By LSW in forum 1991 - 1999 (E36)
    Last Post: 06-27-2012, 10:30 AM
  3. M3 coilovers on my 325i..?
    By Sam Hamm in forum 1991 - 1999 (E36)
    Last Post: 08-24-2010, 02:05 PM
  4. intermittent check engine light on 1993 325is
    By ryan85stjoe in forum 1991 - 1999 (E36)
    Last Post: 02-06-2008, 05:15 PM
  5. ?'s on 1993 325is
    By vaderz06 in forum 1991 - 1999 (E36)
    Last Post: 12-13-2005, 01:51 AM
