Who has done it?
Worth it?
Or should I just replace with a new one?
I have my front subframe off and now would be a good time.
TIA
99 M3 STU/ GTS3 Project
Read this, maybe helpful:https://www.bimmerforums.com/forum/s...steering+joint
I have had the 5 series solid unit for ~2 years now, no issues and I'm pretty violent with my car.
http://www.jegs.com/i/Flaming-River/...nMoaAgMK8P8HAQ
No issues so far. In fact I couldn't even feel any difference.
No surprise the solid (non articulating) joint caused issues.
E30M3 race car - solid replacement installed for over 10 years, no issues.
Worth It?
If its a dedicated track car any rubber you can get out of the car other than the tires is a win.
jimmy p.
88 E30 M3 Zinnoberot - street
88 E30 M3 Lachsilber - SCCA SPU
87 E30 M3 Prodrive British Touring Car 2.0 Litre
04 Ford F350 - V10
06 Audi A3 Brilliant Red / 2.0 / DSG
I may be mistaken but I remember it's also rubber because it's made to shear off in a severe accident
This is what I was thinking. Car is a race car period.
No rubber is good.
Does this have the correct size and # of splines for our e36 cars?
Which year 5 series? Thanks
E34 steering U joint. I've had one on for two years now with no issues. Improved my steering feel over the stock rubber.
I also use the Flaming River u-joint, on a 1994 325is with stock rack and column. Works fine, fits great.
If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
The only thing you need to do is; drill a dimple for the set screw in the upper shaft. Use red loctite for the set screws. Then tighten down the jam nuts.
I've had the E34 joint for about a year. Works well.
Thanks guys. Ordered an E34 coupler. Will give it a wirl.
J
