Results 1 to 7 of 7
Thread: 1999 M3 Wont Crank
    Jan 2017
    nj
    2001 740i Sport
    1999 M3 Wont Crank
    hey i'm having a really weird issue with my e36. the battery is good, the alt is good, and im pretty sure the starter is good. My car wont crank and i tried bypassing the clutch safety switches, and getting a new key. It runs and drives fine with a push start. I tried a new ignition switch and even with the new one there isnt 12v at the yellow and blackwire when the key is in start position, only when in run. there are no fault codes. It wont start via the ignition no matter what i do, also doesn't dim or click when trying. Thanks
    Nov 2012
    CA
    96 318ti
    if you have verified that all stuff like the starter and battery are in working order, then I would suspect your EWS module. People on the forum say you can bypass it by cutting a wire. search around.
    DIY 96Z3 (M44): Drive Belts, Starter, H2O Pump
    DIY 00ZM (S52): Gauges: clock, battery, oil
    Jun 2010
    NY
    1997 328i
    Your starter is bad.
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by mnguyen84 View Post
    This was the same problem I had occasionally on my 95, which I fixed by cutting the EWS wire. I think the later 99 EWS is more complicated to bypass. Try jumping the starter first though.
    Dec 2002
    Offshore GOM
    E36 M3's
    Where is this EWS wire? Mine just left me stranded... battery is fine... just won't crank.
    Dakar 95 M3 (4/95 manufacture)
    Techno Violet 97 M3 (12/96 manufacture)
    Alpine White 16 535i M-Sport (10/15 manufacture)
    _________________________________
    "I have no idols. I admire work, dedication and competence." -- A. Senna
    Illegitimus Non Tatum Carborundum
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Casebrius, I've answered your thread on the Gen'l Mechanical forum. Don't chop any wires....this is bad information.
    Chris Powell
    BMWCCA 274412
    Dec 2002
    Offshore GOM
    E36 M3's
    For anyone reviewing this thread, check ALL fuses related to OBD and make sure they are intact. Mine ended up being fuse 46 (95 M3). The OBC seemed to work fine, but that fuse was blown and prevented the car from starting.
  1. e36 M3, wont turn over / crank
    By crayons232 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-13-2021, 12:34 AM
  2. 1999 M3 No Crank
    By HOFFMANN707 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-25-2017, 09:10 AM
  3. Wont crank or start e36 M3 1995
    By lolacoll in forum 1991 - 1999 (E36)
    Last Post: 05-09-2016, 09:07 PM
  4. 2005 M3 wont crank up!
    By Mishu13 in forum 2001 - 2006 M3 (E46)
    Last Post: 09-16-2013, 10:30 AM
  5. 1995 M3 wont crank over need help
    By ka3aka in forum 1991 - 1999 (E36)
    Last Post: 11-03-2009, 08:35 PM
