1996 BMW M3 Coupe 5 Speed Hellrot/Modena
-1996 Bmw M3
-Hellrot / Modena
-164k Miles
-5 Speed manual
-Cold AC/ Heater works
-Compression tested 2 weeks ago at 150-155 across all 6 cylinders
-Originally an Illinois car, but was a florida car for a significant portion of its life. There is no visible rust on the paint or under the car. There is some very slight bubbling where the side skirt meets the rear fender.
Factory Options:
Rear spoiler
Sunroof
18 Button OBC
Harmon-Kardon
Maintenance:
Several maintenance records come with the car however it is not fully documented. I have kept track of all the repairs/preventative maintenance during my ownership as follows:
Past 5k miles:
-Mobil 1 15w-50 w/ OEM filter
-Replaced hood struts x2
-Power steering flush
-OEM PCV/ICV replaced
-Slave Cylinder replaced OE
-Brake flush
-Front wheel bearings x2
-Anti-rattle clip x2
-Bosch Alternator/Pulley
-Spark plugs
-Swaybar endlinks
Lighting:
-Euro style glass headlights
-Euro style clear corners
-Euro style smoked tails
-Euro style clear side indicators
-LED interior
Wheels/Suspension/Brakes:
-Apex Arc-8 17x9, 17x9.5
-Sumitomo HTR ZIII 245/40, 255/40
-BC Racing Coilovers w/ camber adjustment
-Poly swaybar bushings
-Rear camber arms
-Drilled/Slotted rotors
-Gold calipers
Engine:
K&N filter
Otherwise stock
Interior:
-Original Modena Vader Interior, could benefit from a leather repair/conditioning. Id say this is the area that needs the most attention.
-Manual non-heated seats
-Aftermarket metal shift knob (unknown origin)
-Aftermarket head unit
Areas that need attention/What i had planned:
-New shifter bushings
-Leather treatment/Carpet Shampoo
-Cooling system refresh (comes with car)
-Paint is in great condition for a 21 year old car but there is clear coat peeling on the sideskirts and a small spot on the roof
-Rear passenger tire was rubbing due to the 255s. The rubbing has since been remedied but the tire shows wear on the sidewall
-Passenger window motor works intermittently
-Needs new pads soon
Parts included:
-ECS Stage 2 Coolant system refresh- includes new water pump, thermostat, thermostat housing, water pump pulley, belt tensioner, OEM bmw coolant, and belts
-OEM steering flex joint
-OEM M3 badge
-Center driveshaft support bearing
-Rear swaybar endlinks
-ZHP shift knob
Located in Indiana
In no hurry to sell.
DO NOT PURCHASE THROUGH PANJO
List Date: 7/23/2017
For more info, click here to view the original listing: 1996 BMW M3 Coupe 5 Speed Hellrot/Modena
This item is no longer available.
Reserved
I bought a ZHP sedan last month for the same price. If this was available when I was looking, I would have had a very very hard time deciding between the two. This car looks awesome. GLWS.
Was the compression test done with the motor cold?
