Results 1 to 8 of 8
Thread: no brake lights - brake light switch?
    Dec 2011
    New York, NY
    2002 porsche carrera
    so my brake lights are not working. i have no idea when this started, but clearly this could be an issue.
    - there is no warning on the mid
    - the bulbs are good
    - when i pull the fuse, i get "brake light circuit" warning on the mid
    - i took a look behind the pedal, the switch is there seemingly fine, with no corrosion. the plunger appears to release and depress with brake pedal movement.
    could that switch be faulty without throwing an mid code?
    where else should i be looking?
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    Broken wire in boot lid
    Dec 2011
    New York, NY
    third brake in the rear window light does not work also. is a wire in the boot lid still a possibility?
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    no, it is the switch... a broken wire throws the warning code, the switch doesn't - it just never activates the brake lights
    '91 850i 6sp (mint) (sold)
    Dec 2011
    New York, NY
    ok...well the switch is available for <$20, so i'll SWITCH it out and let you guys know.
    thanks!
    Jul 2017
    Santa Barbara, CA
    2009 MB CL63 AMG
    If you're going to remove the switch, pull/pry the red collar entirely forward with the brake pedal depressed before pinching the two release tabs to release the switch from the bracket. Don't ask me how I know.
    Dec 2011
    New York, NY
    yup. brake light switch. replaced. lights work again.
    i just cut the tip of the plunger/button off and slid the collar and button out, rather that trying to pinch and pull.
    Sep 2008
    Santa Barbara
    Good job
  1. No Cruise? BOTH Brake lights stuck ON?
    By defaz in forum 1996 - 2003 (E39)
    Last Post: 04-06-2008, 01:12 AM
  2. Bad install - no rear running/brake lights but trunk mounted works
    By anokieinla in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-31-2006, 02:58 AM
  3. Brake Light Failure/Tail Light Failure when switching tails
    By GUINNESS in forum 1992 - 1999 M3 (E36)
    Last Post: 12-20-2006, 02:33 PM
  4. switch indicator to tail light (brake)?
    By saad in forum 1996 - 2003 (E39)
    Last Post: 05-22-2005, 10:47 PM
  5. Brake Light Circuit or switch??? Need help
    By PhantomX in forum 1991 - 1999 (E36)
    Last Post: 11-18-2004, 08:51 AM
