Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Thread: Bought a 1989 750iL E32, Fools Errand or Awesome.
    Sep 2012
    Layton, UT
    E23 1984 733i
    I need something to go cruise in. I've been looking for an 80's 535 or a 1970s BMW Bavaria. Apparently there aren't any left. So I took the next logical step and bought on of BMWs most complex cars from the 1980s. A 750iL. It the Long Wheel base 5.0L V12 model. The rear seats are electric and recline.
    Here are a few pictures of it.
    It was running on 6 cylinders when I got it. Half of the plug wires were broken. I just ordered new wires and plugs. I cleaned up the distributor caps and rotors. Yes that's one per side. Everything is doubled on this engine except the oil filter.
    I've got the engine stripped now of everything that was in the way of getting the spark plugs out. I had to order new intake boots for it. They were dry rotted.
    This is after I detailed the engine bay the best I could with the limited room there is.
    Sep 2012
    Layton, UT
    E23 1984 733i
    The tail lights were broken. So I ordered some after maker units. So when they showed up yesterday I swapped them out.
    Old and busted
    New and Pretty
    Old and busted
    New and Pretty
    Half the headlights are broken. Actually just the high beams. So I found some French headlights for the high beams and I'll swap them in when they arrive next week.
    New headlights (high beams)
    And the best part of it is, I only paid $550 for it. ha ha ha
    Jul 2016
    Chicago, Illinois
    are slow
    Mmm, not bad.
    To get the plugs out, all you need to do is lift the washer tank and move the battery terminal out of the way.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Quote Originally Posted by sawtooth4x4 View Post
    You could have saved $$ with the plug wires, I have ignition wires for the M70 on stock. See my website below under shogun goodies.
    Sep 2012
    Layton, UT
    E23 1984 733i
    Well crap. That would have been nice to know. They already shipped unfortunately. Otherwise I would have.
    Anyone have a good source for distributor caps and rotors. I think mine are original.
    Tomorrow I'm picking up some style 5s. These are the bolt together type. Not the one piece like I have currently. $200
    Jan 2005
    Japan
    Do not buy cheap no name distributor caps and rotors, too much trouble. Bosch, Bremi are o.k., FCPEURO has them on sale at the moment https://www.fcpeuro.com/BMW-parts/75...90&m=20&page=1
    Jul 2016
    Chicago, Illinois
    are slow
    Shogun sells some other stuff like door handle gaskets, quality items if you ever need them.
    Sep 2012
    Layton, UT
    E23 1984 733i
    Does anyone have a quick way to tell which gearing I have and wether or not I have an LSD?
    Jul 2016
    Chicago, Illinois
    are slow
    does anyone have a quick way to tell which gearing i have and wether or not i have an lsd?
    Sent from my iphone using tapatalk
    1989 = 3.15
    Jan 2005
    Japan
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by shogun View Post
    I've never seen the Diff Lock option absent on a 87-90' car, I guess US buyers all wanted it.
    It'd make sense to remove it when ASC is specced.
    Jan 2005
    Japan
    Only the US had the LSD standard on the early models. The 3.64 was probably also a US thing. The 3.15 was standard across all build years in Europe. And LSD was an "pay extra" option untill the ASC+T became standard on the 750.
    Sep 2012
    Layton, UT
    E23 1984 733i
    Well, nothing exciting to report really. Mostly waiting on some parts. Most of them should be here today.
    I installed a new stereo, changed the oil and filter.
    I also hit up a junkyard today and found most of the missing tool kit for it, got some trim pieces, and a front turn signal light.
    Sep 2012
    Layton, UT
    E23 1984 733i
    Well I got it back together and running for the first time. But it sounds like I have a bad injector. So I guess I'll try running some cleaner through the tank. If that doesn't fix it, I'll have to get them rebuilt.
    I also drove it around a little. It's very slow. So I also think the cats might be plugged up. Not sure yet. I'll figure it out though.
    https://youtu.be/VoQ9vXZl94w
    Jan 2005
    Japan
    very slow? when you switch ignition on, does the EML light in the cluster come on and then disappear? If it never comes on and goes out or if it stays on = limp mode.
    Sep 2012
    Layton, UT
    E23 1984 733i
    The EML comes on then shuts off when the engine is running.
    Sep 2012
    Layton, UT
    E23 1984 733i
    Looks like it's staying on.
    How do I get rid of limp mode.
    Jan 2005
    Japan
    That means the engine runs in limpmode. Do you have a diagnostic tool? Or make a stomp test, info on my website.
    Can be many things causing limpmode, a defective donut, MAF, no spark on cylinder 6 or 12 where the donuts are, CPS, dirty throttle valve motors, distributors, rotors, defective fuel pumps, yes, the M70 has 2 of them, and so on
    Sep 2012
    Layton, UT
    E23 1984 733i
    I found a used Peake Research BMW scan tool near me. I'm going to go buy it tomorrow. I'm not just going to start randomly replacing parts because that gets pricey
    Sep 2012
    Layton, UT
    E23 1984 733i
    Ok. I was able to get rid of the eml light. One of the throttle control plugs wasn't in all the way
    I can go through all the gears.
    But I still don't have any power.
    It feels like I'm driving a Volkswagen bug currently. No power and slow as hell.
    I still have a check engine light.
    Jul 2016
    Chicago, Illinois
    are slow
    Run a stomp test.
    Sep 2012
    Layton, UT
    E23 1984 733i
    What is a stomp test
    Sep 2012
    Layton, UT
    E23 1984 733i
    Ok. Figured out the stomp test.
    I'm getting code 1222
    I looked it up and it came up lambda control 1.
    I'm trying to look that up now.
    Sep 2012
    Layton, UT
    E23 1984 733i
    seems like I have a dead fuel pump. lol.
    easy enough to fix at least. I'll order two new ones. Call it a day with some new fuel filters as well.
    Then i just need to see if the rear wheel bearing is toast.
    This car is a money pit, but easy to work on.
    Jan 2005
    Japan
    E36 fuel pumps are much cheaper and also fit and have enough througput, here I posted the dimensions of the original Bosch fuel pump dimensions
    see 2nd post in that thread http://www.bimmerboard.com/forums/posts/1264535/
  1. My 1989 750il thread - AKA A Fool's Errand
    By biasvoltage in forum 1988 - 1994 (E32)
    Last Post: 10-17-2017, 08:18 PM
  2. 1989 750iL DC53568 / Real Highline or not?
    By fritzenos in forum 1988 - 1994 (E32)
    Last Post: 12-19-2014, 07:43 AM
  3. 1989 750il e32 bmw white/beige CA car 150k
    By e35m5csl in forum 7 series
    Last Post: 01-28-2011, 02:06 AM
  4. E32 1990 e32 750il $1500 whole car or parts drives great
    By e35m5csl in forum Whole Parts Cars
    Last Post: 12-27-2010, 10:35 PM
  5. WTB: 750il E32 or E38 Black W/Ivory Int.
    By WILDMAN in forum BMW Cars For Sale / Wanted
    Last Post: 09-25-2006, 10:11 PM
