Hello all!
I recently had my CCC go out, so I replaced it with a used one off eBay and went to my indy to have the entire car programmed and brought up to date. The build specs of my car has the 6FL option as verified by decoding the VIN and having the USB/aux-input ports inside the center console. Research says that the TCU will handle it on LCI models and later model TCUs whereas with pre-lci TCUs the ULF2 module is needed. My question is do folks with LCI models ('08+) have only a TCU to enable the ipod integration? A look on the left side rear wheel arch will show the TCU mounted vertically where the ULF module would be mounted below it horizontally I believe.
Thanks!
