Hello!
I recently purchased a BMW E30 320i, and I am overall quite inexperienced with cars. This is my first car, and it does not need much work. It is almost all original parts, and I just want some pointers on what to purchase for the car, or what to alter on the car. I would possibly like to do an engine swap for the car and/or get a performance chip, but I am not sure where to buy chips for the 320i except from eBay. I know eBay is not a trusted website to buy chips from, and I would definitely prefer to stay away from that site. I'd overall like to keep parts I need a lowish cost, but just overall tips would be great.
The car has no accidents, and has quite low km with only 135,000.
The check engine light is on, and I am not quite sure why. If there are any common problems I can check for please tell me!
Thank you!
If it's your first car, do not do an engine swap and honestly don't waste any money on power increases. Safety first: fluids, brakes, tires, suspension bushings.
Interested in vintage cars? Ever thought about racing one?
Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!
Are you sure it's the "Check Engine" light or simply the "Check" light? The "Check" light is all by itself between the two main gauges while the "Check Engine" (if equipped) will be down with all the other idiot lights. The "Check" light indicates a fault is being shown on the overhead check panel. Also "Check" will show until the brakes have been pressed since the system can't check the brake lights until you do that.
"Howdy, Folks!"
I have to agree fully with this advice ..... a lot of money and pita to swap that engine, and I have not found a source for a M20B20 chip for mine, so I would just keep it stock and well maintained ... and enjoy driving it. If this is your first car it is very likely that the car is still faster than you are ... learn to drive safely and do the basic car maintenance.... and then someday make a decision to sink some serious money into something faster or more powerful, if that is still a priority.
... forty-three years of driving before I get behind the wheel of a BMW .... and I am thinking, "why did it take me so long?"
... and then after another 4 years I can't believe that I have two of them !!
Yeah thanks it is only the Check light, and not the check engine. It is in fact the Coolant so I will get some work done on that.
Alright awesome thank you!
Congrats on your "new" bimmer and welcome to the forum!
With such low km and mostly original shape, once you replace timing belt & water pump and fix coolant issue your next step is to check the tires - they've probably aged out. Each tire has Tire Identification Number that encodes the week & year of manufacture. You may be ok on tires up to 10yo but I'd replace at 6: tire compounds harden over time, losing grip in the process.
https://www.tirerack.com/tires/tiret...170723142002:s
Now you're sure that you can go, please make sure that you can stop! Brake pad check, fluid condition, and bleeding the lines is next on your list. I'd take it to a shop for this - they can do a power flush and, if dirty, clean the reservoir and replace fluid as needed. They're also more likely to spot wear-item failures like worn grommets, O-rings, etc in the system. And as a new, learn-as-you-go DIY'er, brakes are not what you want to make your first mistake on.
Alright awesome. The brake pads were recently replaced, and ill be sure to take it to a shop for a check. I know I will need to replace the tires, so i think ill just do some drifting then replace em.
When I picked up my E30 in December, its mismatched 13yo tires were "ideal" for "drifting" - I slid through a few corners and felt pretty pleased with myself.
... but, yeah, I keep my drifting to the virtual tracks of Forza ... not an IRL drifter
