Results 1 to 3 of 3
Thread: 2008 BMW 335i HUGE electrical issues
    Jul 2017
    Oklahoma
    2008 e92 335i
    Hey everyone,
    So I was cruising along a few weeks ago when every light from abs to transmission popped up and the car started to drive horribly. Took it to the stealership and they diagnosed it as a bad alternator. I replaced the alternator (not there) with an OEM Bosh and it had the same issue. Then I replaced it again and it had the same issue. There's something draining off power and it's causing the entire car to freak out. The battery has been tested twice and it's fine. We're currently charging it to full to see if that helps.
    Any thoughts on the issue?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Load test the battery to be sure. Definitely a power issue, check your battery connections, ground straps, etc. You might also check that the battery was properly registered.
    Jul 2017
    Oklahoma
    2008 e92 335i
    Hey Rocket,
    We're leaning towards the battery or something drawing power on the car somewhere unnaturally. It's weird because the car will die, but it will start back up without jumping the battery after a day or two.
  1. 2008 BMW 335i E92 DSC/ABS issue, need help
    By greg328 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-23-2015, 02:18 PM
  2. 2008 BMW 335I - constant issues
    By SILOSVICK in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-10-2015, 03:32 PM
  3. 2008 BMW 335i Coupe Only 8k miles!
    By xdavidx in forum 3 series & Z Series
    Last Post: 08-08-2008, 05:25 PM
  4. Comparison Test: 2002 BMW M3 vs. 2008 BMW 135i vs. 2008 BMW 335i
    By garrafa in forum 2001 - 2006 M3 (E46)
    Last Post: 05-16-2008, 12:03 AM
  5. Just picked up new 2008 e90 335i... HUGE THANKS TO BRECHT BMW!!!
    By Dave Schotz in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-14-2007, 11:14 PM
