Results 1 to 12 of 12
Thread: Stuck transmission fill plug
    Feb 2014
    Albany, New York
    1998 BMW 740IL
    Tried to get out full plug with 8mm hex key and almost completely stripped. Used pb blaster and still no luck. Any ideas? Is there another way to fill transmission fluid?
    Jan 2017
    Riverside California
    1998 BMW 740i
    Well this is going to sound crazy but with a pump I filled mine through the line that connects to the transmission cooler. Did you already drain it?
    Sent from my SM-N910V using Tapatalk
    Feb 2014
    Albany, New York
    1998 BMW 740IL
    No. I read I should get the fill plug loose first
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Quote Originally Posted by Dada007 View Post
    Glad you at least read first. A lot of people drain then worry about the plug. If you've already sprayed PB blaster, you can try and taking a torch around the plug to try and break loose any material around it and expand the metal and try again.
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    You are using an Allen socket...Right?...
    Oct 2014
    NE
    2000 740IL
    Quote Originally Posted by kouks View Post
    its a torx
    Feb 2014
    Albany, New York
    1998 BMW 740IL
    Yes I'm using an 8mm hex socket. My full plug is not a torx.
    Aug 2012
    Simi Valley, CA
    328, 525, 740, R1200RT
    A few strikes with a sharp chisel and hammer will get it out.
    Dec 2011
    Lancaster CA
    Quote Originally Posted by mooll View Post
    its a torx
    No its not. If you use a Torx you will definitely strip the bolt. Ask me how I know.
    If you use the correct size Allen (Hex) head stripping the bolt is very difficult. You may break the socket first.
    Soak in PB Blaster, use a chisel maybe with it. I recommend against heat on the trans. Trans fluid is hydraulic fluid, and is highly flammable.
    Jun 2013
    Toronto, Ontario
    '95 740i
    Yeah my first thought was "no flame near tranny fluid!"
    Good job on reading first, but again try using that fluid line to fill it up. Who knows though if you can even get the drain plug off though? =D
    || 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    Quote Originally Posted by Old525i View Post
    I would be wary of this. The pan is fairly thin - you don't want it cracked to add to your problems
    Oct 2014
    NE
    2000 740IL
    wack the end of ur ratchet with a BFH. plug will pop with a swing or 2. ive had to do this on every e38 trans fill / drain plug that ive had to remove
    idk thats weird are we talking about the same thing.. on every 5hp24 i've touched it's been a torx 50 or 55 ( cant remember exactly ) and i've never stripped one banging on my ratchet with a BFH and they always came loose with a swing or two
    these are really hard to strip, so good going OP
  1. Stuck transmission fill plug...HELP
    By samtheman48 in forum 1983 - 1991 (E30)
    Last Post: 03-15-2014, 04:35 PM
  2. Transmission fill plug on 2000 328i (auto)
    By dlerette2000 in forum 1999 - 2006 (E46)
    Last Post: 05-11-2008, 01:11 AM
  3. Stripped transmission fill plug
    By MACTAR! in forum 1983 - 1991 (E30)
    Last Post: 08-21-2006, 11:41 AM
  4. transmission fill plug?
    By kpc01 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-21-2005, 07:13 PM
  5. Cant remove transmission fill plug
    By m3style in forum 1992 - 1999 M3 (E36)
    Last Post: 04-26-2004, 05:18 PM
