Results 1 to 5 of 5
Thread: Bmw 645 tapping noise with a difference
    Aug 2014
    england
    645ci 2004 convertible
    iv just done the top end hydraulic lifters,, near side and of side, lifters, checked intermediate fingers ,checked cams , all this was done as the car had a loud single tapping,
    put car back together a all sounds good on all cylinders, but very mechanical sounding tapping is still there, i noticed yesterday if i remove the oil cap slightly the noise goes completely, but obviously the engine runs lumpy, due to lack of vacuum ie oil cap off, anyone any idea ??
    doing my nut in
    Feb 2015
    Athens, AL USA
    E60, E46
    I pulled valve cover on my 650i and found nothing...but have been reading about injectors being the source of this tapping...have you had success finding the problem?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It is usually the vacuum pump - try removing the vacuum line that runs to it and see if the noise changes (it won't go away completely as it only removes a small amount of vacuum) That is why the noise goes away when the oil cap is removed as it relieves the load on the pump.
    My BMW Repair YouTube Channel
    Feb 2015
    Athens, AL USA
    E60, E46
    Hi...can you explain how a break vacuum pump has anything to do with the lifters and a noise coming from rear drivers side of the engine? I did replace lifter, seals and have stopped smoking...runs good...just this load knocking noise from drivers side head near the firewall....I just don't see how a mechanical pump on the front of the engine has anything to do with it....thanks for helping me understand...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Lifting the oil cap removes the load from the vacuum pump - and so it stops knocking. The pump is driven by one camshaft and the noise can be transmitted along it. But, the proof is in the pudding as we say - if removing the vacuum line makes a difference then the pump is the main suspect.
    It sounds implausible, but I came across this when working on my pump:
    http://www.meeknet.co.uk/E64/Timms_B...eak_Repair.htm
  1. 2004 BMW 545i Engine Failure at 68k loud tapping noise
    By galenpowers in forum 2004-2010 (E60,E61)
    Last Post: 12-31-2015, 01:21 AM
  2. HELP! 1992 BMW 325is Multiple Noises With Videos and Explanations
    By YoungSpiffy in forum 1991 - 1999 (E36)
    Last Post: 04-30-2013, 11:51 PM
  3. BMW e39 5 series with different wheels?
    By RiegerD in forum 1996 - 2003 (E39)
    Last Post: 01-04-2011, 02:38 AM
  4. Replies: 34
    Last Post: 01-02-2011, 02:52 PM
  5. 1994 BMW 320i Coupe Misfiring, Slow to start, tapping noise.... etc etc etc
    By stevenleeosborn in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-11-2007, 11:23 AM
