Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    SF Bay Area
    98 M3 vert, 05 X5
    Yeah, ordered a used/refurbished one yesterday.
  2. #27
    May 2012
    St. Catharines ontario ca
    2010 BMW X5 M option
    My former vehicle was an 03 Infiniti G35. Parasitic drain was common and it was a fault on the radio/heater control bd. PITB for sure. Glad you figured it out.
  3. #28
    SF Bay Area
    98 M3 vert, 05 X5
    Update: As I said in October, I replaced the Radio/MID unit with a $70 used one, but wasn't completely convinced it was the culprit. The beginning of my startup problems in June 2017 was the switch from my OEM BMW battery to a AAA battery. Since I'd gotten a refund on the battery, plus visa credits, I decided to swap it out for an Interstate Megatron 85 Plus. No issues since. The installer tested the AAA battery and said it was fully charged and up to snuff, but the cold cranking amps dropped to the floor when a load was applied.
    So lesson-learned: stay away from AAA batteries!
  4. #29
    Jan 2020
    Massachusetts
    05 BMW X5 4.4
    So I went through almost exactly every thing you described in this thread. My mechanic removed the radio fuses as you mentioned, no problems till like a dummy I wanted to listen to music with a friend and figured could remove a fuse from the on board computer and replace it when I'm done. But after apparently that fuse is more important than I thought because the battery completely died and won't start even after replacing said fuse🤦🏾*♂️
    So I'm just alil confused at the final solution you came too? Did you replace the radio head unit, the battery or both? Because I would like to keep the original head unit since it's integrated with the dash display.
  5. #30
    Aug 2020
    United Kingdom
    BMW X5
    Hello. I'm probably a little late to these forums however I also have a BMW X5 2005 with the same issue. Something is draining my battery overnight leaving it flat next morning. I was wondering if you ever found a solution to this? Thanks.
  6. #31
    Dec 2013
    Chicagoland area
    EXOTICS
    You have to put in some work,
    search for the circuit causing the drain.
    Once you have the circuit, you can narrow down the component.
  1. Yet Another Weird Battery Drain Issue :: 2002 X5 3.0
    By 4reagan in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 08-13-2015, 11:46 AM
  2. Disconnecting battery terminals on 01 X5
    By enyrgee in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-15-2008, 02:35 PM
  3. Battery Drain on fuse 21
    By genocide98 in forum 1983 - 1991 (E30)
    Last Post: 10-20-2007, 08:47 PM
  4. 2005 X5 3.0i Loaded Auto
    By MPowerM3 in forum BMW Cars For Sale / Wanted
    Last Post: 06-28-2007, 07:22 PM
  5. NOS on a X5 3.0i
    By jrpaz in forum Forced Induction
    Last Post: 05-09-2003, 04:38 PM
