Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 165
Thread: Bored Bleedsblue: "budget" minded Brembo BBK
  1. #101
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Brent is on top of this but if you guys have specific questions I’m happy to chime in. Sorry been MIA you guys and gals have been keeping me very busy.
    -Greg
  2. #102
    Iceland
    BMW 850
    So you will be offering a set that will keep the low ET?
  3. #103
    ATX
    Sundry old Grrrrmans
    Quote Originally Posted by Fatandre View Post
    Andre we are testing with 8" M System ET20, is that in the ET range you desire?
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
  4. #104
    Iceland
    BMW 850
    I am running a et10 and et 19 throwing stars
  5. #105
    ATX
    Cheap F30 kit, you would likely need a spacer. We are testing with 8" ET20 and that may need a small spacer, even.
    The AP Racing kits (one $, one $$$ LOL) will accommodate low offset - the $$$ kit will soon be on Greg's M5 and Jason's 540.
    - Brent
    www.angry-ass.com
  6. #106
    Iceland
    BMW 850
    Waiting for info on the expensive one
  7. #107
    Jul 2015
    Portland, OR
    '90 535i, '91 M5
    Also eager for these BBK options. Y'all are doing the lord's work.
  8. #108
    Airplanes & Hotel Rooms
    E34 M5T
  9. #109
    ATX
    For budgets:
    I'm about to install the F30 335i front brakes (Brembo 4 piston, 340mmx30 rotor) on my M5. We have produced a batch of the required spacers (they go between the knuckle mounting tabs, and the caliper) and as soon as I have some miles on the setup, we'll be releasing this as a "kit" - including offering great pricing on new components (calipers, rotors, pads).
    These calipers and rotors are very easy to find used, as well! I believe we paid less $400 for the pair of perfect 4 piston F30 Brembos, and perfect 340mm rotors. Tough to beat that! They clear certain 17s, such as M Systems.
    The same spacers allow you to run the F30 "M Performance" brakes, which are roughly the same caliper (painted, and radiused) but with a 370mm rotor. We are not playing with that on our personal cars, due to the cost relative to other options, and the fact that 370mm is a ton of rotor (overkill for my car, particularly). They also require 18s, but consider this an option as well if the greater thermal capacity of the big rotor is appealing.
    "Real" BBK:
    Greg's M5 is now running his 6 piston, RadiCal AP Racing setup with 355mm rotors on full-custom AAS aluminum hats. This setup can be reproduced (UnrulyGrace is also getting a set, potentially with less race-oriented calipers), but it is very costly - think at least $3,xxx for the front axle.
    Rear axle:We are currently slammed with finalizing some big products before our end-of-August Drive 4 Corners meet, at which we are a primary vendor, but we plan to build a rear axle brake upgrade - not so much a BBK. We will utilize the E46 M3 rear rotor (328x20mm), likely the matching caliper, and build a custom caliper carrier.
    With the rear kit, and the 340 F30 option, we are simply seeking to match or surpass the late '94+ M5 factory braking system, as those parts are unobtanium and the ATE calipers are serious anchors.
    We will likely build some rear 4 piston setups if there is enough interest.
    This is not currently a priority, though UnrulyGrace is interested in this and may help drive development.
    - Brent
    www.angry-ass.com
  10. #110
    Oct 2008
    Denver
    '91 M5
    Thanks for the update. Very interested in your results and am seeing what kind the $/lb the different options are.
    Current Fleet:
    E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
    Past:
    E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
    E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
    E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
    E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
    E39 1998 528i 5-Speed Black on Black - Sold locally.
    E34​ 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
  11. #111
    ATX
    Quote Originally Posted by TGreene View Post
    I know you are a light-weighting pioneer like us, Trevor, so we hope to really deliver for guys like yourself.
    The cheap, out-of-the-box standard 335i F30 option offers a very light caliper (comparable to Brembo F50, a tad lighter than the E31 Brembo), but a bout a 24# rotor. It is a true two-piece which is great, and they are SOOOOO cheap, but the extra ~3# over the late '94+ M5 345mm rotor is unfortunate.
    ECS Tuning offers a lighter rotor for this kit, but it's near $700 for the pair.
    Our custom aluminum hat setup, paired with AP Racing calipers, is going to be the lighter option for sure - whether 4 piston or 6.
    - Brent
    www.angry-ass.com
  12. #112
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Id assume this f30 340mm kit would fit the e24 late chassis with appropriate 17” wheels for clearance
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  13. #113
    ATX
    Quote Originally Posted by GazM3 View Post
    Gaz I don't know E24s, but the F30 kit should fit anything that also fits E34 brakes (E31 come to mind, I guess E24 if the former is true).
    - Brent
    www.angry-ass.com
  14. #114
    Alachua, FL
    '92 BMW 535i/5 Lazurblua
    I wonder if 06 Audi A4 4-piston calipers would fit... There's some at my local JY. Also an 02 745Li.
    Sent from my Z956 using Tapatalk
  15. #115
    Dec 2005
    E24, E34 x2, E36
    I’m pretty sure the hub bolt dimensions and offsets are the same for /e24(late)/e28/e31/e32/e34/and oddly e36 m3 eurospec. Don’t market them too much tho until I purchase a set as like the Porsche calipers the price will go up.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  16. #116
    Iceland
    BMW 850
    what about offset and et?
  17. #117
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by BleedsBlue View Post
    E32 and E28 come to mind as well.
    95 E34 553i6 LS TR6060 Project
    93 E34 525iA Beater with no heater
    VANOS kicked in yo!
  18. #118
    ATX
    Quote Originally Posted by mrkanda View Post
    No idea about Audi! The E65/66 use a single piston caliper, so not of interest to us.
    LOL. We got you, Gary. There are a ton of F30 335s being broken here; can you find the same in AUS?
    The E36 (NA and Euro) have the right bolt dimensions but the offset for the E36 is wonky. The rotors and hub are a higher offset, as we found when test-fitting rotors.
    Andre, we are still pending a test-fit with our stainless steel caliper spacers, at which point we can share more offset details!
    - Brent
    www.angry-ass.com
  19. #119
    Iceland
    BMW 850
    Any new stuff happening here?
  20. #120
    ATX
    We are live, Andre: https://www.angryasssolutions.com/parts/stage-1-bbk
    We have confirmed fitment, no spacer, over an E34 M5 M System (17x8 ET20). The spokes are close but it clears perfectly!
    We are offering a discount to the first person with any of these chassis, to try our product and confirm fitment for us:
    • E32
    • E31
    • E28
    • E24
    Of course, if there are fitment issues we will work with the customer to either refund, or get it to fit!
    We are assuming based on cross-compatability that our brake kit will work, but do not have a test car for these chassis.
    - Brent
    www.angry-ass.com
  21. #121
    Iceland
    BMW 850
    I would be glad to test them on my e31.
    I have the 345mm Nurburgring set now and was wondering how the front would work with the big rear I have.
    Also I was wondering which calipers co with this as I know the blue ones that go actually on the F30 have different mounting holes than the grey ones.
  22. #122
    ATX
    It is very close to the 345mm set-up (technically not Nurburgring ), in terms of bias and weight!
    It would be more cost-effective if you were able to find calipers and rotors locally, I can promise; shipping 75lbs and a large box to Iceland will cost a fortune! Our adapter kit ($55) would be much cheaper to ship.
    Let me know if you are interested and I can PM part numbers for the calipers and rotors!
    - Brent
    www.angry-ass.com
  23. #123
    Iceland
    BMW 850
    I am interested but was hoping it would be much lighter than my 345mm kit.
    I will soon be in the states so we could ship the adapters there.
  24. #124
    ATX
    The F30 rotors are 4# heavier (each) than 850csi 345mm, but the F30 calipers are about half the weight of 850csi ATE calipers. It's still lighter and much cheaper/more available!
    - Brent
    www.angry-ass.com
  25. #125
    Iceland
    BMW 850
    Yes. I am having a problem sourcing discs for the 345mm
    I want to go with your adapters
  1. BBS RGR and Brembo BBK...
    By JQP-M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 04-29-2003, 09:05 PM
  2. Brembo BBK!
    By ///M3 CRAZY in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 11-20-2002, 05:10 AM
  3. BRAND NEW 12.6" Brembo BBK FOR SALE!! E36/E46
    By Amir in forum BMW Parts For Sale
    Last Post: 11-17-2002, 04:18 PM
  4. "POLL" of possible new Categories
    By Bob ///M3 in forum Forum Software Questions & Suggestions
    Last Post: 02-27-2001, 07:53 PM
  5. "Poll" of possible new categories!
    Last Post: 02-27-2001, 07:44 PM
