Hi, currently stripping a 728i (1998) with a remote keyfob and all matching barrels.
to swap this into my other e38, also a 728i (1998) which only has the emergency/none remote keyfob,
what would i need to swap as well as the barrels to get the remote fob working in the other vehicle,
or can the remote key just be coded into the ews of the car im putting the barrels into?
For the key to start the car, swap the small black chip inside the key.
The remote to unlock the car can be reprogrammed to any car with a simple procedure.
Yes ... ALL keys (remote & non remote) have a transponder/chip inside them. This has been in affect since Jan/1995 when EWS II debuted. Take note of the small gray rectangle drawn into the illustrated head of each key below:
But God help the next owner of the car that needs a new key and they have no clue that the lock barrels have been changed and no longer match the car's VIN (let alone know what the original matching VIN is for the lock barrels that were replaced). They will go to the local BMW dealership to order a new or additional keys...and when they arrive and have been paid for...they won't work in any of the lock barrels you replaced. You're creating a FrankenBimmer nightmare for the next person if they ever need a new key.
If it were me, I would just put the original key and the one with the key fob on the same key ring. Program the fob to handle the locks and continue to use the single key for the ignition.
Ditto the Mayor's suggestion. ^^^^
You can program a used remote key to lock/unlock and arm/disarm your FZV & DWA systems by using your original non-remote key to initiate the 1st step in remote key programming (STEPS 1-3). Then when instructed to start pressing the buttons...you do this with your used remote key.
This will initiate any BMW remote key that transmits the same RF (radio frequency) of 315 MHz (this is what the US market BMW remote keys use) to communicate with your GM to lock/unlock & arm/disarm FZV (central locking) & DWA (anti-theft alarm siren) systems. The remote WILL NOT start the car...but it can lock & arm the car remotely.
Below are the directions for initializing remote keys. And YES...you must follow the instructions as written...don't fudge or change anything. All doors MUST be closed...all doors MUST be unlocked...turn ignition to KL R (ignition position 1...not position 2):
No...not any BMW keyless remote...but yes if the remote uses the same frequency and operated the keyless entry systems used during the generation that your BMW was manufactured in. That would mean, a remote from an e38/e39/e52/e46/e53...these are the generational cousins that used the same communciation bus and other systems that are compatible.
A remote from a different generation that operates over an entirely different bus system probably won't work...if it did...I'm sure it would be a huge discussion on old BMW forums...the "look what I can do" threads would be everywhere. (lol)
These are the remote keys that can be programmed to your BMWs FZV/DWA even though the key blade doesn't fit. But the other caveat is...the new style remotes (w/color Roundel) are powered by a rechargeable battery that is kept charged when its inserted into the ignition. If the key blade doesn't fit your ignition, then the battery doesn't get charged...thus the remote buttons won't work. You will need to find a way to keep that type of key charged if you want to use it as a remote only. The old style keys don't have this issue because it uses a replaceable battery.
Ok I thought I would be able to get a newer model remote & just program it to my 1995 740i
The new generation BMW communication bus (LIN/BSD/MOST/ P-Can/K-Can/etc)...will not communicate with the old generation communication bus and modules you have on your 95? Plus again, most of those new style keys have a rechargeable battery (some don't) and are charged through induction from the CAS (car access module) which the 95-2001 e38 DOES NOT HAVE.
Not saying that it can't be done...it just won't be simple.
Your remote key info is sent from the key, to the aerial built into the rear windshield...then onto amps in the C-Pillar which then end up at the GM. From their the GM sends commands to FZV to lock/unlock the vehicle and to DWA to arm/disarm the alarm siren:
To use remotes from new gen BMWs that have a more sophisticated/complex bus system...you would need to install some facilitating module to interpret the data commands so that your car could understand them. And the CAS system also uses multiple "aerials" and a 125 KHz radio frequency for its "comfort access" features. Again, our old generation BMWs don't have a CAS module (we have a GM or GMIII).
Here's some BMW info about the new generation BMW's CAS module which may help show how more complicated it is versus the FZV/DWA systems used during the e38/e39/e46/e53 generation BMWs:
- https://www.newtis.info/tisv2/a/en/f...ystem/BRtYuJ0U
- https://www.newtis.info/tisv2/a/en/f...minals/XocPBph
{new gen BMW communication BUS}
