Has anyone used this device before?
https://www.plex-tuning.com/products...knock-monitor/
looking for first hand experience with inline 6's.
About 4k cheaper then an in cylinder pressure monitoring system.
Capital Driving Club Car # 102
How to turbo your car:
Step one. Install ecu and learn to tune and or have it tuned.
Step two. Install injectors and retune.
Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
Step four. Retune car
Step five enjoy
I only have experience with the Knock system on the Motec M1 ECU.
Andre Simon is probably the best person to ask, as he has used all of the knock products out there....
Another option is the Phormula system...
That better be awsome considering it costs as much as a standalone ecu with knock monitoring. It better be able to hear knock with the sensors in the glove box.
It costs about 1k. And thinking that this could be used for multiple vehicles not just one.
Step five enjoy
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
key words. Tune is not proven it works but is not set up for max power.
Step five enjoy
http://www.jandssafeguard.com/
Though the best and cheapest option is some home made det cans. Its hard to beat your ears and brain for filtering.
Ill have to research that product. Looks like its around 600 bucks.
Step five enjoy
It doesn't seem to do anything more than an AEM Infinity does on the knock side... and misses out on all that cool standalone stuff, like running your engine and adding safeguards based on the knock processing, in the process.
Add-on boxes are such a 1990's/early 2000's method of tuning. There's really no excuse in using one these days unless it's to stay well under the cost of a standalone system.
Voted - waste of time, this would have been much better if it came out 10-15 years ago.
It does communicate with standalone which is interesting. Only two communications at a time. Knock level + one of the other 7 features.
So sounds like consensus is its not for a hobbyist.
Step five enjoy
For real time tuning on the dyno, I'm told that some tuners prefer to use the Plex box, and then plug those #s back into a Motec M1 or AEM Infinity.
For what I'm doing, I find the Motec M1 knock system to be all that I need. It's really easy to correlate signal traces against engine parameters...which is tough with an external box.
It's a tuning tool mainly that allows you to additionally use headphones as det cans to listen in (and filter) knock.
Yes many aftermarket ECU's already have the option to detect knock, but you have to set it all up first and the best way to do so is to actually verify there is knock in the first place by listening to it. That's where this comes in.
Not everyone will see a use for it, but tuners would. I have a similar box (not a nice) that I use sometimes to listen for knock, it allows me to switch filters on the fly for the connected headphones and graph out the peaks. The Plex is nicer due to better options and inputs. But works similar.
Yea, I understand what det cans are, but modern bandpass filters and high sample datalogging make it pretty easy to tell if there's actually knock occuring. Especially since you can back off timing and see if the knock signal remains.
what ive noticed while tuning on the street is the following.
Trying to tune the car your self + have det cans on + looking for cops + trying to figure out if this is knock + trying to determine which load/rpm range you are at.
Ive actually given up trying to tune well on the street. I have no access to a dyno and this is what i think the next best thing. Yes its expensive but it allows me to tune the car much better then i have had in the past.
Car will remain at 75% ability until i can either get on a dyno or get this tool.
Maybe i just like tools. (reached out to knock sense) 100 bucks vs the 1k. May do the same thing but i not as easily.
Step five enjoy
Step five enjoy
But why not put this money towards a modern ECU that will then save your bacon if you get some bad gas or an injector clogs, or the fuel pump starts giving up etc. etc.?
I could totally understand if this thing was about half the cost it is. Sure, you can tack it on top of an existing, if outdated setup for less than the cost of a standalone. As it sits, you're like 80-90% the cost of a standalone that can do 99.999% of what this can, and a whole lot more.
New ecu that can handle this is about 1700? correct?
Time require to rewire the current engine harness. ~3hours
Time to learn new software ~10 hours.
Rough hourly rate that my time is worth ~75 an hour.
~975 on top of the ecu.
Total about ~$2675.
Now what happens when i start screwing with a second car or third car?
use the cheap ecu i know, with this tool and keep the price overall low.
From what i seen it seems like it would take about 30 minutes to get up and running on this unit. I like that feature a lot.
Step five enjoy
Seems like a cherry picked way of looking at things with some high time estimates.
But if you want hypothetical time estimates:
Parts it'll cost to rebuild your engine after your old "no safeguards" ECU let it blow up $1500
Machine work to rebuild $800
Time to pull engine, reassemble, reinstall ~15 hrs
Total cost of not running a nice ECU: ~$3425!!!!!!!!
Step five enjoy
For the people that might have purchased a course....the webinars are free.
https://www.hpacademy.com/previous-w...knock-monitor/
