Results 1 to 8 of 8
Thread: Pop Up lights - can they be left up at all times
    Jul 2015
    London, UK
    1994 BMW 840i
    Hello
    I am trying to diagnose temperamental pop up lights.. when i flick the switch sometimes one goes up, both, other side, etc. Same when i switch off, sometimes one goes down and the other doesn.
    i am going to check relay K39, and LCM (in that order), but in the meanwhile I was wondering is there a way to leave both up?
    Can I simply remove K39 once both are up? or is it dangerous to LCM or any other component?
    thanks!
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    the only danger is that a stone chip might break the glass. Remove the headlight actuator relay once they are up. This will give you the opportunity to check that relay for broken solder joints - usually just reflowing the solder will fix the problem. The LKM will not be harmed by this action.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Nov 2013
    Whitney, TX
    97 850CI
    Check the wiring harnesses that go to the headlights. They are normally in very bad shape if they haven't been repaired/replaced already.
    Desecrator of all things Sacred
    Apr 2008
    UK
    BMW 850CSi, E53 X5 4.8iS
    Almost certainly an LKM module failure. You may find the module smells burnt if you remove it or there may be signs of overhaeting on the outer plastic case.
    Jul 2015
    London, UK
    1994 BMW 840i
    Hello all- thanks for replies! I have opened K39 looks pretty good I attach some pics.. Has anyone got the wiring diagram of this relay so i can test with a 12V PSU?
    I too feels this is a LCM prob :-( not looking fwd to the expenditure of a new item.
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    First, reflow the solder at the base of the relay where the base of the relay connects to the pcb. Pretty sure that you have cold or cracked solders joints there which definitely will cause the problem you are describing. Common issue...
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    '91 850i 6sp (mint) (sold)
    Jul 2015
    London, UK
    1994 BMW 840i
    This has worked a treat!!! Amazing! U guys are stars!
  1. 88 E32 Interior Lights - What should be lit up?
    By scipio in forum 1988 - 1994 (E32)
    Last Post: 11-23-2015, 09:15 PM
  2. Flat-spotted my tires--can they be helped?
    By hukalaki in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-19-2008, 10:41 PM
  3. Replies: 7
    Last Post: 10-11-2003, 01:35 PM
  4. Replies: 18
    Last Post: 06-05-2003, 02:01 AM
  5. Replies: 4
    Last Post: 02-20-2002, 03:29 AM
