Results 1 to 7 of 7
Thread: No high or low beams but all other lights work.
    Jul 2017
    North carolina
    97 bmw 740il, 92 bmw 525
    Does anyone have an idea what the problem is, Help.
    Dec 2013
    Chicagoland area
    EXOTICS
    Check for headlight relay.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Which of your cars? That helps us to help you. For example if it is your E34 525, then check the LKM = light control module, the black one like a video cassette in the fuse box, inside are the relays for low and hi beam and the foglight relay.
    Jul 2017
    North carolina
    I have a e38 97.
    Sorry this is my first time here. I have a 97 BMW 740iL E38. All the turn signals Park brakes flashers signals, they all work but the headlights do not high beam or low beam. And I've replaced the bulbs in both and still nothing.
    Jul 2017
    North carolina
    Where is the headlight relay located for my 97 BMW 740iL E38.
    Jan 2005
    Japan
    I will move it to the E38 forum
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by RodneySr View Post
    Just for verification...you DO have the ignition turned to position 1 or 2, right? If not, the headlights do NOT illuminate if
    All exterior lighting for the 97 e38 is under the control of the LCM. See info below on how the relay & fuses where incorporated into the LM, then to the LCM, then to the LCM III:
  1. 1996 318i - heat & gas gauge not working, won't crank, but all other accessories work
    By fmodyssey in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-26-2015, 04:05 PM
  2. Looking for high and low beam relays to troubleshoot lights
    By Sparksterc43 in forum 1975 - 1983 (E21)
    Last Post: 11-07-2013, 03:48 PM
  3. No Flashers or Low beam?
    By E21fun in forum 1975 - 1983 (E21)
    Last Post: 12-30-2010, 12:29 AM
  4. HIDs in High Beams (or Low Beams) Write-up!!! - PICTURES!
    By clumpymold in forum BMW Rides & Events
    Last Post: 06-22-2009, 01:31 AM
  5. NO High or Low Beam
    By VINCE325 in forum 1983 - 1991 (E30)
    Last Post: 07-24-2008, 02:25 PM
