Results 1 to 12 of 12
Thread: 99 bmw m3
    Mar 2015
    NC
    97 328i, 99 M3, 02 325i
    99 bmw m3
    I have a 99 M3 and someone pulled out infront of me so I slammed on breaks didnt get clutch in fast enough stalled out. Now the cars steering is locked no power at all put the key in ignition its almost like its stuck into the 1st position because engine will not turn over. Im guessing its the ignition but i searched forums and couldn't seem to find my issue. I dont have the spinning tumblr that i see everywhere mines actually stops in the crank position just does nothn no dash lights or anything. Any help would be grately appreciated or if there is a post for my problem please send link thanks.
    Current cars 1997 BMW 328i Alpine White, 1999 BMW M3 Fern Green, 2002 BMW 325i Orient Blue, Past cars 2002 BMW 325i Steel Grey R.I.P.
    Jun 2010
    NY
    1997 328i
    Wiggle the steering wheel while you try to turn the key. Don't force the key.
    Mar 2015
    NC
    Hi and thanks for the reply but Ive tried that wont unlock at all.
    Dec 2013
    Chicagoland area
    EXOTICS
    Just like a reboot on your smartphone,
    try disconnecting the battery for 10min.,
    may reset whatever is causing the problem.
    Did you actually make contact with the other vehicle?
    Mar 2015
    NC
    Yes i tried disconnecting the battery to try and reset everything but no luck. Also I didn't hit the other car they just sped off ������. This is the first ive heard of a problem like this.
    Dec 2013
    Chicagoland area
    EXOTICS
    Your going to need a diagnostic scan with BMW specific scan tool/software.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    You said "almost like it's stuck in 1st position because it wont' turn over". Are you able to physically turn the key to the run/crank position? If so and nothing happens, start checking fuses and power.
    Mar 2015
    NC
    Yes im able to turn the key to run and crank it just does nothing and the steering wont come unlocked. Its as if the ignition has no power. Also thanks for all the replies to this post. But ill check the fuses when i get home today.
    Mar 2015
    NC
    Hi just wanted to update anybody that have this problem it was indeed the ignition. Thanks for all the responses from the people who tried to help!
    Dec 2013
    Chicagoland area
    EXOTICS
    Thanks for the update
    Mar 2015
    NC
    Yes sir!!!!
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by jayjay720 View Post
    So what was the exact problem/resolution?
  1. F/s: 96-99 BMW M3 Strut Hats
    By 95MMM in forum BMW Parts For Sale
    Last Post: 04-01-2004, 06:34 PM
  2. For Sale 99 BMW M3
    By DinanM3 in forum BMW Cars For Sale / Wanted
    Last Post: 11-17-2003, 04:59 PM
  3. Fs Ecis Intake 96-99 Bmw M3 328 Ebay
    By M3D in forum BMW Parts For Sale
    Last Post: 09-03-2003, 08:20 PM
  4. 99 BMW M3 Coupe
    By nidlezp in forum BMW Cars For Sale / Wanted
    Last Post: 08-22-2003, 12:10 AM
  5. Fs: '99 Bmw M3
    By Maximus in forum BMW Parts For Sale
    Last Post: 07-02-2002, 12:34 PM
