Results 1 to 7 of 7
Thread: Throttle body giving problems
    May 2017
    Germany
    2003 e46 320i Touring
    Question Throttle body giving problems
    First off, hello everyone. I've been using the forum as a source for information for a while now, but this will be my first post.
    So about 2 months ago my 320i(m54b22) started giving me the fault code "p0121 throttle/pedal position sensor/switch A...". The fault code goes paired with the following symbols:20170523_141218.jpg(I just cleared the check engine light before I took the pic)
    Now just over a month ago I decided to buy a second hand OEM throttle body from Ebay and replace my throttle body, and I also replaced the DISA with a vaico one as it clearly had no life left in it anymore.
    After I swapped them out everything worked completely fine, however, after a month and +-2000km (1242mi) I am back to the original problem. First it just happened once and after clearing codes I could drive again for a while, but now it's permanent. ( also went like this on my original throttle body)
    Just as it happens I got two more codes today, "p1638 and p1639 throttle stuck temporarely and Permanently". Paired with those to codes the engine just revs up and down the whole time in neutral ( I don't dare to drive with it)
    With only p0121 the symptoms were as follows:
    200-300rpm higher resting rpm
    car stutter when releasing gas pedal at speed and with a gear in.
    seemingly less power (failsafe mode?)
    Tomorrow morning I'm going to dig down to the throttle body again and clean everything, untill then I wanted to ask if any of you have experience with this problem, tips or any other means to help me on this problem.
    Also is there a realistic chance that I just have bad luck and bought a throttle body that happened to break down after 2000km?
    Thanks in advance
    Jun 2012
    New Mexico
    2003 328i
    It is possible that your replacement conked out. Try another one.
    Dec 2013
    Chicagoland area
    EXOTICS
    Clear codes,disconnect battery for 10~30mins.
    Then read this and follow procedure:http://www.e46zone.com/forum/topic/4...daption-reset/
    May 2017
    Germany
    Tried this but it didn't work good idea though.
    Considering I actually cleaned the used one before installing it I figured that it's probably not dirty. I ordered a new one now and then I'll see how it fares..
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    Maybe a plug was not fully connected? Some of the throttle plug connections are very tight.
    Also you could have overlooked a vacuum line when working on the throttle area.
    Try checking those things and then try the throttle adaptation procedure MIKYZZ4 mentioned.
    Hamburg, NY USA
    e23, e32, e34, e39
    My sons 99 528i had the same throttle code and cluster lights. His car had no power and couldn't go over 5 MPH. He got it towed to my house and and after some searching I came across this when I pulled the dipstick:
    https://www.youtube.com/watch?v=R3eg4dXr1NY
    I had the CCV stuff, so I swapped it out. I cleaned the throttle body while it was off. Problem gone.
    Just something to look at.
    May 2017
    Germany
    So I ordered a new throttle body but not a OEM one, just some chinese one. Just before I was going to put it in the car I noticed it rattled like some plastic toy that's been broken from the inside. That, along with some other fishy things around that throttle body, made me decide to return the part and not risk it for the biscuit today.
    But while I had everything out I figured I might as well clean all my connectors with MAF cleaner I had lying around and cleaned the throttle body with TB cleaner. I made sure all connectors were attached firmly.
    And what do you know, it worked again! I let the car idle for a bit and then drove for about 30 mins without any problems.
    After it worked again I had this vague idea of the throttle body connector indeed not being attached properly the last time I disconnected it... I'm really not sure but it could be that some of the extremely poor roads in France shook it loose after not being connected properly in the first place. And then maybe after a while it got even more loose causing the problem to be more frequent maybe? Who knows.
    Anyways I guess it's solved for now, If any problems come up with it in the future I'll report back.
    Thanks everyone for your suggestions!
  1. Idle Problems after Big Bore Throttle Body
    By Sada in forum 1992 - 1999 M3 (E36)
    Last Post: 04-04-2012, 01:47 PM
  2. Bmw 3 Series With Head Gasket + throttle body problems | Should I buy?
    By isse in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-08-2009, 01:22 AM
  3. installed new throttle body, Very high idle problem?
    By jskin1510 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-05-2009, 10:19 AM
  4. off topic help from the community...throttle body problem
    By Whatabout in forum New England - US
    Last Post: 09-14-2009, 11:37 AM
  5. throttle body removal problem
    By philip77o in forum 1991 - 1999 (E36)
    Last Post: 01-05-2008, 01:25 PM
