Results 1 to 3 of 3
Thread: n42b20 intake manifold wiring problem
    Apr 2017
    Romania
    E46 318ti
    Hello,
    I discovered a problem under the intake manifold of my 318ti N42b20.
    The Differential Pressure Sensor it was disconnected and the wiring from intake manifold to actuator is missing... I was almost to die when i discovered..
    Here's the photo.
    1 - Differential pressure sensor disconnected. I reconnect it but then car is running verry bad with sensor connected. Idle is fluctuating between 400 and 900. I think that the sensor is broken or maybe it needs the actuator connected to work properly ? I don't know.
    2- The actuator wiring is missing. Others N42B20 have a 3th wire to connect the actuator. The cable which is marked with white. At my car is completely missing. I was wondering if the guy who had the car before me has cut the wire. But i din't discovered any broken wires there.
    As i am not a mechanic, i would like to ask you guys what is the role of the actuator which is not connected ?
    The car is running fine, no lights on, fuel economy mixed 7.7. Everything looks fine.
    I'm going to buy a new cable who have the wire for the actuator. I think that i need to remove the intake manifold.
    I something hard? Can i do it by myself? Any diy will be welcome!
    Thank you !!!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the engine computer (DME) for codes. Yes, the differential pressure sensor may be part of the problem but other issues may be the root cause. Scan it and post them.
    Apr 2017
    Romania
    E46 318ti
    Quote Originally Posted by MarcoZandrini View Post
    The only error that i get from DME is - 00278E Differential-pressure sensor, intake manifold.
    I get that error because Differential pressure sensor is disconnected. If i connect it, it will run very bad, the idle rpm is going rough and is fluctuating between 400 and 800. Like a tractor.
    The differential pressure sensor works good if the actuator is not connected?
    What is the role of the actuator?
    I was looking for the wire diagram of the intake manifold cables but i didn't found them..
    Thanks!
  1. how to remove the intake manifold wiring harness
    By robmac36067 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-03-2008, 02:33 AM
  2. 95 e36 m3 wiring problem under intake manifold
    By e36m3myantidrug in forum Engine Conversions
    Last Post: 04-26-2008, 07:55 PM
  3. OBD2 M52 parts - Intake Manifold / Wiring Harness / SILVER LABEL 413 DME / E30 parts
    By Ryan-N-Austin in forum Engines, Performance Parts & Software
    Last Post: 06-12-2007, 11:24 AM
  4. ko performance M50 Intake manifold install problem
    By Eurogp in forum 1992 - 1999 M3 (E36)
    Last Post: 05-20-2007, 12:46 AM
  5. OBD1 intake manifold,wiring harness PVC
    By 93bmw325is in forum BMW Parts For Sale
    Last Post: 03-09-2005, 08:58 AM
