Page 3 of 3 FirstFirst 123
Results 51 to 54 of 54
Thread: Quick power modifications to an e39 540i
  1. #51
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    The manifold in the pic above is from a non vanos 540, fatter runners, and is on my car.
    The one I took off my 540 is the one I don't need, it's a tu manifold. All the runners are tapped and will require an injector for each runner.
    One injector before the throttle body is fine, that's what I did on my Z and on the 540 before I did one on each runner.
  2. #52
    Aug 2008
    New York, NY
    BMW 540i
    Ok i'll try the one jet at first.
    If want to install a used m5 diff rear, is it direct swap or other mods needed?
    1997 540 / 6 Sport, 2001 540 staggered rims
    Suspension = Bilstein B8 Performance Plus Struts, Xeon headlights & fog lights, LED tail lights, Evo short shifter, Custom air engine intake, 3 inch dual exhaust hollow cats,NGK iridium spark plugs, removed -clutch delay valve
  3. #53
    DeWitt, Michigan
    '97 540i/6, '97 328i
    #5 is the biggest gain for the $$.
    Attachment 633760
    I've got a spare tu manifold that has fittings for 8 injectors to be screwed into. 175+ boost here.
    You could always just do a single injector, much cheaper. Don't forget the cost of the N2O.
    It's just the manifold that I drilled and tapped then inserted the correct fittings that the injectors would screw into.
    This plus a welded diff is the definitive best bang for the buck, speed and fun-having upgrade for a 540. The open diff ruins all potential fun-having, period. The extra brute torque from the NAAAAAWWWSSSSSS negates the need for the 3.15 diff.
    Of course, you can quickly run out of clutch with this setup, but a $100 eBay 6-puck clutch disc is proven to hold over 500ft-lbs with an M5 pressure plate.
  4. #54
    Aug 2008
    New York, NY
    BMW 540i
    I still have no idea why anyone would want a fart can! Even kills the Hondas
  1. Is it wise to buy an E39 540i M-sport?
    By LASwede in forum 1996 - 2003 (E39)
    Last Post: 09-11-2016, 08:23 PM
  2. getting ready to do an e39 540i Lsx swap...
    By James39 in forum 1996 - 2003 (E39)
    Last Post: 06-24-2011, 09:39 PM
  3. Looking to buy an e39 540i sport 6-speed
    By greek318is in forum 1996 - 2003 (E39)
    Last Post: 08-26-2009, 09:48 PM
  4. Exhaust for an E39 540i similiar to the 03' Z8?
    By E39540i in forum 1996 - 2003 (E39)
    Last Post: 09-08-2006, 01:59 AM
  5. Replies: 3
    Last Post: 11-11-2002, 11:50 PM
