The manifold in the pic above is from a non vanos 540, fatter runners, and is on my car.
The one I took off my 540 is the one I don't need, it's a tu manifold. All the runners are tapped and will require an injector for each runner.
One injector before the throttle body is fine, that's what I did on my Z and on the 540 before I did one on each runner.
Ok i'll try the one jet at first.
If want to install a used m5 diff rear, is it direct swap or other mods needed?
1997 540 / 6 Sport, 2001 540 staggered rims
Suspension = Bilstein B8 Performance Plus Struts, Xeon headlights & fog lights, LED tail lights, Evo short shifter, Custom air engine intake, 3 inch dual exhaust hollow cats,NGK iridium spark plugs, removed -clutch delay valve
This plus a welded diff is the definitive best bang for the buck, speed and fun-having upgrade for a 540. The open diff ruins all potential fun-having, period. The extra brute torque from the NAAAAAWWWSSSSSS negates the need for the 3.15 diff.
Of course, you can quickly run out of clutch with this setup, but a $100 eBay 6-puck clutch disc is proven to hold over 500ft-lbs with an M5 pressure plate.
I still have no idea why anyone would want a fart can! Even kills the Hondas
