RM European Auto Parts
Results 1 to 17 of 17
Thread: 2007 335i AT - Not Shifting past M2 (2nd gear auto)
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Hi,
    I recently picked up an automatic 2007 BMW 335i with sport paddle shifting. The symptom is when I move from Park down to Drive, it shifts into M1. From M1 I can shift manually up to M2, but can't go past M2. This is true while driving also, I cannot go past M2 which limits me at around 20 mph.
    I have pulled my code list from INPA. The code that concerns me the most is A0B1 which "A0B1 Input, selector lever/clutch switch, implausible".
    Any suggestions on where I should start? I have pulled up the automatic shifter gate and soldered the broken wires together (common symptom of not being able to shift into sport mode). I was thinking of changing the ATF fluids, but didn't want to spend money where it wasn't necessary.
    Full Code List:
    INPA Error Code
    Description from Google
    • A6CF
    • Recirc Function
    • C90B
    • C90B - JBE: PT-CAN communication fault
    • A731
    • A731 JBE: Supply clip 30g-f (I cannot figure out what the supply and clip are for, but it's something about Terminal 30g-f obviously)
    • 5087
    • 5087 - One-touch gearshift or M gate switch
    • 604E
    • 6050
    • 6050 FR Transmission channel (usually means replace RDC Trigger)
    • 9CD5
    • 9CD5 - Communication with seat-belt handover, passenger's side, disturbed
    • A0B1
    • A0B1 Input, selector lever/clutch switch, implausible
    • A0B2
    • CAS Supply Error
    • A0B4
    • A0C1
    • CAS: Output, Terminal 50 RS
    • A092
    • A092 - Normalization,slide/tilt sunroof
    • A669
    • A669 - FZD: Interior lights at front
    • A66E
    • A66E - FZD: Interior light, rear right
    • A66A
    • A66A - FZD: Reading light, front left
    • A3AD
    • A3AD - INSTRUMENT CLUSTER: Message(engine data, 1D0)
    • A3AE
    • A3AE - INSTRUMENT CLUSTER: Message(engine speed, 0AA)
    • 931D
    • 931D - KOMBI:Undervoltage or overvoltage
    • A554
    • Alive telephone: SOS failure
    • E18D
    • WAKEUP NETWORK UNSUCCESFUL : FAULT CODE E18D
    • E190
    • E190 Ring diagnosis check done (error_ring_diagnosis)
    Thanks,
    Hao
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Have you attempted to clear all the codes in the DME as well as the EGS to see which one come back right away?
    Be sure to screen shot each page, as there is more info with each code(s)
    Next go for a drive and see if any other code(s) populate into the system. At the same time you can watch the live data to see what is going on, for this I would take a friend to drive the car while you watch.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Thank you for the quick response! I will clear the codes tonight. If I clear through INPA will it clear both the DME and EGS? I'll have to google this a little haha. I'll clear codes and come back with updates tonight.
    dworthy's Avatar
    Nov 2010
    You will have to go into each. While they both will talk to each other, in such that a transmission code will set a check engine light.
    Darin
    Current:
    Past:
    M-Flight Member
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    So I pulled these two codes even after the reset on the transmission.
    1) 5087
    2) 511B (apparently common with Alpina Flash)
    The 5087 appears to be my issue with not being able to go past M2. Any tips on how to resolve this?
    E R R O R M E M O R Y
    Date: 19.07.2017 17:57:18
    ECU: GS19D
    JobStatus: OKAY
    Variant: GS19D
    RESULT: 2 error in error memory !
    5087 Hardware Eingänge Tippfunktion
    Error counter: 2
    Logistic counter: 40
    1. Umweltsatz
    Mileage 234776 km
    Pegel an L1 Pin (1=low 0=high) 1.00 0/1
    Pegel an L2 Pin (1=low 0=high) 1.00 0/1
    Pegel an L3 Pin (1=low 0=high) 0.00 0/1
    Pegel an L4 Pin (1=low 0=high) 1.00 0/1
    Pegel an Tip+ Pin (1=low 0=high) 1.00 0/1
    Pegel an Tip- Pin (1=low 0=high) 0.00 0/1
    Pegel an M-Gassen Pin (1=low 0=high) 1.00 0/1
    Batteriespannung 12.00 Volt
    Zustand WK Wandlerkupplung offen 0-n
    Schaltart Schaltart P nach P 0-n
    Substrattemperatur 25.00 Grad C
    2. Umweltsatz
    Mileage 234776 km
    Batteriespannung 13.68 Volt
    Substrattemperatur 32.00 Grad C
    Tipp- und M-Gassenschalter unplausibel
    Testbedingungen erfüllt
    Fehler momentan nicht vorhanden, aber bereits gespeichert
    Fehler würde kein Aufleuchten einer Warnlampe verursachen
    Error code: 50 87 24 00 00 00 00 02 28 72 A3 DA 96 1E 41 72
    A3 DA AB 1E 48 00 00 00 00 00 00
    511B Fehler Codierung
    Error counter: 1
    Mileage 234776 km
    Batteriespannung 0.00 Volt
    Abbtriebsdrehzahl 0.00 1/min
    Mittl. Radgeschw. ang.Raeder 0.00 km/h
    Status Zuendung undefiniert 0-n
    Codierung war fehlerhaft
    Fehler momentan vorhanden und bereits gespeichert
    Error code: 51 1B 61 00 00 00 00 01 28 72 A3 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00
    Jul 2004
    Houston, TX
    36 Cylinders
    Stop.
    Stop.
    Don't try anything else until you get the transmission coded correctly.
    When was the Alpina transmission flash done? Why no coding after?
    5087 = "Hardware Inputs inching function" Whatever that means.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I got "Hardware Entrances Tip Function".....whatever THAT means. My guess is that there's a bad transmission shifter switch; either at the shifter, or at the trans itself. That's only a guess; I'd be hooking up ISTA to follow a guided test plan for the faults.
    But yeah.... "ERROR CODING" is problem #1 !
    Chris Powell
    BMWCCA 274412
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Thw Alpina flash was done by the previous owner. Any tips on how to flash back to factory transmissiom settings? Do you think this will help the issue?
    Regarding the transmission switch. I bought a used automatic shifter assemnly on ebay. Does anyone have a good DIY? I saw one on youtube, but it involved removing most of the interior and lifting the car to get to the shifter cable. Thanks again for the help!
    Jul 2004
    Houston, TX
    36 Cylinders
    You can keep the Alpina flash, but code the transmission with NCSExpert. All the Alpina flashes I have done (+ coding) never threw codes.
    I don't think it's the Alpina flash, but coding needs to be correct first. It may even correct other errors.
    -Abel
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Could you point me in the right direction to recode the transmission? Is it an easy overwrite? I do have NCSExpert, but have never used. I'll try to do some research after work. Appreciate the tips!
    Jul 2004
    Houston, TX
    36 Cylinders
    If you have internet access to the diagnostics laptop, I can log in real quick with teamviewer program and do it for you. It won't take long. You would just need to download and install teamviewer (basic installation, don't create any accounts), and PM me when you are available.
    -Abel
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Thanks to 328 Power 04, no more errors. However I still have the issue of not being able to shift past M2. When I go into drive, it automatically switches to M1. I'm thinking of a transmission replacement. Anyone have a DIY for that? Thanks!
    Jul 2004
    Houston, TX
    36 Cylinders
    Isn't M1, M2 the manual shifting mode? Can you try to put it into an automatic mode? No errors out of the transmission has me skeptical of needing a transmission swap.
    -Abel
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Agreed! Someone from the 335i facebook group reached out to me. Saying they had the exact same problem, but it was the paddle wiring causing this issue. i'm going to disconnect the paddles this evening. I'll report back!
    Oct 2005
    Twin Falls, Idaho
    2007 335i AT
    Just to give an update, someone on facebook recommended I pull the paddle shifter switch (apparently they can fault out and confuse the transmission). This solved the M1/M2 issue! I however have a new issue now with these two codes being thrown. 4F86 & P17E9. My next steps is to reset the codes and adaptation to see if this solves the issue, if not I will be dropping the transmission pan and replacing the fluids. The strange thing is even after the reset, when I put it into drive it moves me into D1.
    INPA Error Code Description from Google
    4F86 Ratio-monitoring Symptom Circuit-monitoring
    P17E8 Ratio monitoring Shift 3-4
    Jun 2016
    ATX
    2008 BMW X5 3.0si
    Did you ever find out what the P17E9 code is? I'm getting it and have not seen an explanation on any of the OBD code sheets I've found.
    Jan 2019
    kentucky
    08 535i
    I was trying to find out how to replace my transmission cable on my 08 535i
  1. What problems should I expect for 2007 335i at 151k miles?
    By kdaigle23 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-24-2017, 01:35 PM
  2. Automatic E39 not shifting past 3rd gear!
    By MrsOso in forum 1996 - 2003 (E39)
    Last Post: 02-25-2015, 11:38 PM
  3. Automatic E39 not shifting past 3rd gear!Part 2
    Last Post: 04-18-2013, 04:11 PM
  4. Automatic 95 540i will not shift past first gear.
    By josetakapele in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-01-2012, 11:41 PM
  5. 335i problems shifting into 2nd gear (auto)
    By Socal335driver in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-23-2008, 08:35 PM
