Results 1 to 13 of 13
Thread: "NEW" to me Z3 driving me crazy instead of me driving it like crazy......
    Jun 2017
    Louisiana
    BMW 2.8 z3, Chevy z71
    Problems I could use some help with: 1999.5 z3 roadster, 2.8 inline 6 cylinder
    THe car had a crunched hood, broken plastic air dams/front bumper cover/ auxiliary fan, the ASC/DSC light was constantly on, steering wheel wobbled on braking....
    Soooooo.... I bought a parts car
    I put new front brakes and rotors..... fixed most of problem but still likely need to do rear brakes as well.
    switched out hood, bumper cover, broken plastics and painted, switched out yaw sensor......
    Got ASC/DSC light to go out, but comes back on. I think it needs calibrating because it comes back on and goes off if I jack up one side of the car..... I've got the cable and adapter for my laptop ordered from ebay and hoping to download all the software to read and calibrate this darned thing.
    Then the red battery light comes on yesterday. I switched alternators yesterday evening and it didn't fix the problem. I replaced the battery and seems to be good so far.
    Now to the most consternating problem: The cursed thing is now making a rattle when I shift (sounds like something is moving up and down, basically two knocks), AND it has developed a slight wobble in the steering wheel which is most pronounced about 25-40 mph.
    I have researched this and think it may be my center support bearing or driveshaft universal joints. I am hoping it's not universal joints because I don't want to part with 700 MORE $ that I'll have invested in this car. It's hot in the south where I live and I've been working my rear off in the heat trying to get this car RIGHT, and it's getting me upset with all the maintenance crap and electrical sensitive b.s. This is my first bmw and I'm getting a little annoyed with my decision to get a German car. The engine that I've adored so well with the smooth power and great acceleration is not seeming as strong anymore, also. Maybe I'm just getting accustomed to it, but I don't think so.
    What I'd like to hear (I took a cursory look at the flex disc/driveshaft coupler yesterday) is what you guys think this rattle is that has suddenly appeared on shifting, along with the steering wheel wobble......
    I bought this car for 2300$, and a parts car for 1350$.... I don't have a lot of cash to throw around chasing the solution, although at 117k miles, I realize that it's due to start having maintenance issues. I'm willing, but just want to get a few miles behind the wheel of my new "investment". I bought the car in order to have a sporty, fun, cheap, not bad on fuel type car to tool around in. I've been doing a lot of "tooling around" under/beside it, rather than in the driver's seat. I'd sure like to isolate this problem and have some insight as to what you guys who are experienced Z3 owners might consider is the likely source of the problem. No doubt something is moving up and down during the shift when power is taken off the driveline by the clutch being depressed. I am just hoping it's not internal. And I really don't want to have to switch driveshafts since my parts car won't move due to an electrical problem that the previous owner had and caused him to sell it.... Not being able to move it around easily makes it a pain to get under.
    Thanks, and sorry for the long post...
    Oh, and stupid question--- do all z3's have the "m" and stripes on the shifter knob, and the m/stripes on the bottom of the steering wheel? Mine is not an M, and I don't understand why it's there on the shifter and steering wheel.....
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Yes to the stripes; makes it confusing to new owners, but at least it sounds like you already have a leg up and know the difference.
    Don't lose sight that you did buy a wrecked car, and you're earning that BMW driver's delight with sweat-equity (some of us, that've been around here long enough, paid over $50k__$52k with taxes, etc.__to get that same feeling by buying them new). Given your effort, you'll get there, but don't give up yet
    Your new-found rattle could well be the center-support bearing; I just changed one for a somewhat local guy (he carried in the driveshaft loose) because his had torn the support diaphragm. Don't overlook the snap-ring in there, and mark the 2-piece driveshaft before separating the halves at the slip-joint.
    Until you can hook up a diagnostic program, you'll keep chasing your tail on fault codes, and you'll get plenty of support on here with that if you need it.
    Oh! The steering wheel wobble; that was what prompted me to respond in the first place!
    Inspect the column real good, as quite recently, someone on here had one break on them!! In their case, a bracket had been rubbing on one of the corrugations, and it cut through as if it was turned on a lathe. If yours shows any marks on it, or is not absolutely straight, replace it!
    Feb 2017
    Suburbadelphia, PA
    1997 Z3 2.8 Roadster
    Quote Originally Posted by Evinrude58 View Post
    Not meaning to contradict Randy, but here is my (believed stock) four-spoke 1997 2.8 Z3 wheel and shifter (prior to replacement of the latter). No M badging:
    Someone may have replaced yours or maybe it was ordered with M items when new?
    Kent, Ohio
    1998 M Roadster
    Not all Z3's, but many came with an ///M wheel, I can't remember whether it was all after a certain production date, or if it was a trim package with sport seats, but it is a fairly common question in these parts. Some unfortunate souls bought their Z3 thinking it was an ///M on this account.
    Jul 2004
    Houston, TX
    36 Cylinders
    Facelift non M came with the M steering wheel. But not the shifter IIRC.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2016
    Oklahoma City, OK
    2000 BMW Z3 2.3
    Quote Originally Posted by Mr Bingley View Post
    Mine has the M badge on the steering wheel, but no sport seats.
    Didn't the M badge signify some kind of sport option that included a LSD?
    How to-videos and more at Cludgecast on YouTube
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Please follow Randy's suggestion. My own 2¢ is that you thoroughly inspect the front suspension, maybe get a pry bar involved to check for play, inspect all the fasteners you may have touched, and inspect the front wheels, lugs, tires, etc for damage. Also maybe check the strut towers.
    Pretty sure all of that is true. Early years I believe it only came on the sport package, in the later years it was standard. At least in the US.
    PRICE CUT on ALL FABRICS
    Jun 2017
    Louisiana
    I'm feeling a lot better. I got my car on my buddy's lift today. I have bad lower control arm bushings which is undoubtedly causing the steering wheel wobble. My new front brakes are good, needing to do rear, though. I changed my manual tranny fluid with the amsoil synchromesh. Old fluid didn't look bad, but will report after a little driving. I still have a little clunk when shifting, but there was nothing bad about the flex disc, I don't feel love he the center support is bad after a little driving lately. I think I'm just not accustomed to a BMW manual transmission. It may be strong, but in all honesty, it's the roughest shifting manual I've ever driven. My first car was an '86 Isuzu 4x4 pickup and it's clutch and transmission were silky compared to this thing. My buddy's 1990 Mitsubishi Eclipse had the smoothest manual transmission I've ever driven.
    This BMW has easily the worst. But I still like the car and am beginning to get it sorted out and am enjoying it. I changed the oil and used a paper lip to reset the oil life lights..... that was handy:
    I've got contracts l arm bushings in the way and after I do the rear diff fluid change, get the transverse acc sensor calibrated, and the passenger seat bushings, I truly believe this will be a well sorted car.
    I'm thinking I will get used to the tranny and get a lot of enjoyment out of. This thing. I can't say it's a hard car to work on st all. Just a steep learning curve, particularly on the electronics.
    I am looking forward to new bushings. I think that will make a huge difference in the feel of the driving experience. I live the little 2.8, although I'm only getting about 23 mpg. I was hoping for a little p. I've read on here some get 30mpg/-- I think they're delusional lol.
    Thx for the responses. I'm thankful that I'm not having the pull the tranny and deal with the dual mass flywheel/-- yet.
    I think when I pull it I'll likely change to a solid flywheel and do the shift pins and rear main seal along with flex disc and complete driveline. Hoping I might get a few thousand mikes behind me on this car first.
    Jul 2004
    Houston, TX
    36 Cylinders
    So did you change the yaw sensor, or the transverse accel sensor?
    Yaw sensor doesn't get calibrated, but the transverse accel does.
    Was the yaw sensor swap a guess? Unless you needed to change both, which I would think a bit unusual.
    -Abel
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    My m shifted very poorly until I replaced the clutch slave line and slave. Now it shifts smooth like my 64 Chevelle SS used to. Rev matching really helps too but yeah the shifter seems sloppy compared to the old Hurst 4 speed.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by Schreier View Post
    No, it signifies nothing at all! You can see how people got confused about what they were buying just because of a little badge!
    Feb 2017
    Suburbadelphia, PA
    I love the little 2.8, although I'm only getting about 23 mpg. I was hoping for a little p. I've read on here some get 30mpg/-- I think they're delusional lol.
    I got >29mpg on one tank (during my 2500 miles of ownership), but you can see via my Fuelly badge below what the average has been on my 1997 2.8. I've noticed a distinct difference (~4mpg) between highway road trips with and without the air cond. running.
  1. New Guy to the Z3!
    By DamSutt1986 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-23-2010, 03:31 PM
  2. new member to the forum. here are some pics of my e46
    By MrRizzmeister in forum BMW Rides & Events
    Last Post: 03-03-2009, 12:56 PM
  3. TIRE Rack sent me 215'/45/17's instead of 225/45/17's
    By hifocused in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-28-2007, 03:23 PM
  4. Happy New Year to the Z3 community!
    By jr1966 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-01-2007, 09:59 AM
  5. Is it ok to drive in "4" instead of "D"?
    By DOO in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-03-2002, 12:45 PM
