I've been searching and found no clear answers on this one. I'm trying to decide what combination of manifold and turbine housing would work to bolt the Borg Warner S300 up to the S50. I'd prefer to stay with a cast manifold for reliability and also want to stay with a bottom mount for the usual reasons. The open T4 turbine seems like it would be the likely choice, but I've read that this won't work with the SPA manifold? What exactly interferes?
I run a boostlogic bottom mount with a Borg Warner S366sxe and had to grind down the block and the compressor cover to get it to fit.
Correct me if I'm wrong, but isn't that a tubular manifold?
Yes.
I'm looking at the S300SX-E 83S74.
I doubt it will fit with any of the usual cast manifolds.
Both raj and pearlz have manifolds known for large fitment.
Sidebar, pearlz we need to compare some logs. 369sxe vs 6870. Both twinscrolls..
1989 535i - sold
1999 M3 Tiag/Dove - sold
Is it the webbing in the block that interferes or is it the compressor housing vs the exhaust manifold? Obviously the latter can be dealt with using a spacer. The former, perhaps using one at the head.
For me it was the compressor cover interfering with the block. I had to grind the shit out of the block and the cover and it still barely fits.
Any chance you have any pictures? Obviously grinding the block isn't my first preference.
They perform well, they are probably the most reliable turbo on the market, and they are cheap.
Every manifold has the outlet flange in a different location so just because it doesn't fit with one doesn't mean it won't fit with another. Have to find someone that has tried it.
With pictures I was hoping to figure out what needed to be done for fitment. I didn't really want to go tubular for reliability sake. I'm not sure if welding a flange on a cast manifold is a more or less reliable option though.
As far as the interest, I can't really speak for others. I was just looking around and saw the matchbot function which provided more info than I had seen previously. I'm more familiar with Garrett stuff, but after comparing them I certainly see the advantages with the Borg Warner in my instance. I wasn't planning to do a full engine build on this car and was just looking for around 5-600hp while keeping boost response as reasonable as possible. The S300SX-E 83S74 looks like it should be able to make ~20 psi at 3000 RPM which is plenty responsive yet still not go off the map at redline.
You keep saying you don't want a tubular manifold cause of reliability ? Okay, don't get an eBay manifold and that won't be an issue. My boostlogic has been on at least three engines, had at least 4 different turbos on it, and at least 50k miles, likely more as I am not the original owner.
SPA manifolds crack too.
I have not heard of anyone running a s3xx on a SPA manifold or any cast manifold.
I definitely know better than to buy an ebay tubular manifold. If I have to go tubular I'll probably have a friend make it for me and go with a twin scroll (my welding skills are not on par with his). I also want to keep the (working) A/C so that sort of limits how elaborate I can get with the manifold.
I might just have to buy the turbo and see how it fits. Part of me thinks an adapter plate might be a viable solution just to rotate the turbo or to point the inlet more toward the passenger side so the compressor housing clears the block.
The way I see it is you can spend a bunch of money on a manifold to run a cheap turbo, or spend a bunch of money on a turbo to run a cheap manifold.
